Ds3 1.6 ehdi not starting, just clicking noise
sixfoottwo
Unread post by sixfoottwo »
Morning all.
Any ideas? Was working fine then went to start it one morning, ignition on but it just clicks away, battery seems OK as I put a volt meter on it and it shows 12.5 volts.
Any ideas?
Thanks.
sixfoottwo
Re: Ds3 1.6 ehdi not starting, just clicking noise
Anyone? The Mrs is without the car and she's nagging me now so any quick answers/thoughts would be much appreciated!
Thanks!!
x 1453
What sort of clicking? What does the voltage do if you measure it when you try and crank it?
The starter on the 1.6 is buried down the back of the engine / gearbox and is a bear to get to / change....
sixfoottwo
RichardW wrote: 01 Oct 2024, 12:49 What sort of clicking? What does the voltage do if you measure it when you try and crank it?
Hi Richard, cheers for the reply!
Clicking is a constant rapid tick tick tick noise.
I'll just update this now, I've since managed to get it started by jump starting using another car, odd that as the battery was showing over 12v although I couldn't test it whilst cranking it..
sixfoottwo
OK, back to square one as it didn't start again this morning.
x 1453
Sounds like the battery has had it then!
sixfoottwo
RichardW wrote: 02 Oct 2024, 10:37 Sounds like the battery has had it then!
Correct, battery is goosed and I never knew stop/start batteries were so expensive!
