Hi, I have a 2007 Citroen Xsara Picasso, I have fitted a Kenwood KDC BT720DAB but this unit does not switch off when you remove the key,
I have disconnected head unit and checked the vehicles ISO plug the purple and red are constant live without the key inserted.
Any advice please
Radio does not power down when keys removed
- x 6963
Re: Radio does not power down when keys removed
It won't if you have wired it to a permanent feed instead of ignition switched.
Fullrotation
So your saying the ISO socket car side has 2 live feeds and no ignition feed that powers down when key removed
- x 6963
Thinking about it, these are integrated into the BSI and are controlled by the VAN network - so it's likely your after-market unit is not completely compatible. You'll likely loose trip computer and MFD display options for vehicle configuration too.
- x 1903
Is it possible that the radio is expecting the ignition controlled feed where the permanent live feed is and vice versa?
Fullrotation
No, without any radio fitted there is 2 constant live feeds, both stay live when key removed, I would have thought 1 should be constant live for radio memory and the other power feed should come from ignition feed and only power on when key is in.
Fullrotation
Found reply from earlier thread, which answers the question
RichardW wrote: ?22 May 2019, 15:27
Note that if you fit an aftermarket head unit, the dash display for the radio and time/date will stop working (and you won't be able to change the time/date). You will need to run in a separate ignition switched power supply, as the OE radio is switched by the BSI, and if you just connect it up, then it won't switch off at key off, or other odd behavior may occur.
Michel
I believe this refers to a C4 Grand Picasso, rather than a Xsara Picasso.Fullrotation wrote: 02 Oct 2024, 15:41 Found reply from earlier thread, which answers the question
I have a Xsara Picasso with an aftermarket head unit. The only thing I've lost is the display no longer displays the radio station.
It doesn't turn off with the ignition. I had the same issue with my Berlingo. The way to solve it is to use Diagbox to reprogram the vehicle and tell it the head unit isn't present. It then worked as you'd expect.
