Berlingo 2017 blueHDI 120ps
This section is for General Enquiries or for Systems not Covered Above
DanieldeMarko
Unread post by DanieldeMarko »
Hi Guys,
Thank you for the nice forum that you have created. I have a few questions for my Berlingo. My multimedia is SMEG + with version 6.3.D.R6.
1. Can I have an Android auto if I can how?
2. How can I do a mirror link?
3. What software can you recommend to me for a full diagnostic? Some people advised me to buy TopScan Pro since Lexia from AliExpress does not support DPF regeneration and some other things.
Thank you for your advice.
x 6945
Re: Berlingo 2017 blueHDI 120ps
You cannot have Android Auto on any SMEG system - end of, it is not supported.
Mirror Link is discontinued in favour of Android Auto and is no longer supported on many phones - once you upgrade your phone or get a new phone you will no longer be able to install the Mirror Link App.
Your only option is to install an aftermarket unit or other system to provide this.
DanieldeMarko
Thank you very much for your prompt reply. What about software and especially DPF regeneration?
x 1938
Unread post by Paul-R »
Take a look at this post viewtopic.php?p=815508#p815508
x 6945
DanieldeMarko wrote: 30 Sep 2024, 11:26 Thank you very much for your prompt reply. What about software and especially DPF regeneration?
This is a question you will have to direct to your supplier of any aftermarket diagnostic equipment you are considering buying, as functions and capabilities vary considerably.
A full chip Lexia Kit will be able to force a regeneration, but it is not recommended to do this because of the lack of cooling when the vehicle is standing still, and the damage the heat generated puts on components.
DanieldeMarko
GiveMeABreak wrote: 30 Sep 2024, 14:26
Thank you. What could you recommend to me? Topdon Scanner?
x 6945
I only use a Lexia VCI with Diagbox as it's as near to the dealer-level tool as you can get.
DanieldeMarko
GiveMeABreak wrote: 30 Sep 2024, 19:55 I only use a Lexia VCI with Diagbox as it's as near to the dealer-level tool as you can get.
Thank you very much. Which version are you using? Can you recommend me?
x 6945
For your vehicle you'll need V9.** of Diagbox for this year and a full-chip kit.
