Torque pro obd2 app
john79
Torque pro obd2 app
Unread post by john79 »
Does any have this or used this app, is it any good for real time diagnostics like telling you how full your soot level's are or when the last regen took place etc
cheers john
steveclv
x 40
Re: Torque pro obd2 app
Unread post by steveclv »
I was hoping someone could answer this too.
I have replaced my monochrome screen on my C5 X7 with an android based head unit and have connected up a bluetooth OBD2 device and just ran the free car scanner to see if it would work - I am getting a limited number of real-time sensor values but am interested to see if a paid for app will give me a full range of sensors.
I have a laptop with diagbox for any in depth fault finding but using a 'dashboard' on the head unit would be neat. I just don't know which is the best app for the Citroen and also whether an app can clear Citroen fault codes or not.
Mihael_M
x 37
Unread post by Mihael_M »
It is possible to use it for information about FAP but it is a very complicated setup. You have to enter the setup and the "Manage extra PID sensors" section.
It is much easier to install the FAP Application . https://faplite.en.aptoide.com/app
For that you need a quality ELM327 for example like this one :
Vgate iCar Pro ELM327 WIFI OBD2 Scanner Bluetooth-Compatible 4.0 For Android
parnell
(Donor 2022)
x 12
Unread post by parnell »
I bought a nexas nexlink obd 2 adapter to install the FAP full version but because my amazon account is on the blink I cannot. Does anyone have any suggestions to get around this ?
Mihael_M
x 37
Try installing the free version. Fap has had no support for a long time. Many who paid through Amazon are dissatisfied.
parnell
(Donor 2022)
x 12
Thanks Michael , as luck would have it I searched a lot for it today and found this user group on facebook
https://www.facebook.com/groups/782769376493666
If you join the group you get access to the file section which contains a fully functioning full version... which does contain everything I need to monitor the DPF condition going forwards.
