Hi help needed bought a 2013 ds5 2.0lt passed it's test last week, last Thursday the windscreen wipers stopped working also the washers the rear wiper still works,
Checked all the fuses under the bonnet all OK, was checking the motors and noticed passenger side had been rubbing on the suspension top mount and worn through the connector, so I sourced two second hand motors which came off the same car and was assured working, but no joy I don't want to keep buying parts I did get a code U1f3A 87 no communication but cannot find what the 87 means, Anyone any ideas before I hand it to an auto electrician, thanks in advance
Ds5 wipers
- x 6950
Re: Ds5 wipers
| Fault Code: | U1F3A 87 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
Philbin
Re: Ds5 wipers
I was thinking because the connector on the left hand motor which I believe is the main motor has been rubbing through to the to a metal pin white wire which i think is live, I am assuming it has been shorting out on the suspension, the fuse was not blown but maybe the relay which i believe are sealed in the fuse box under the bonnet may have been damaged, maybe just let an auto electrician sort it, thanks for helping
Michaelmap
- New User
Re: Ds5 wipers
Do you found the problem? It happened me the same, when give 12v+ directly to the right side motor everything works. I found a 30A fuse that s not getting current with ignition on. I'm having a bad Time finding the right diagram for my fuse box (BSI?)
