citroen c4 piccasso add blue 1.6 2015 mk 2? clock spring
Spitfiremowers
- New User
i lost all steering wheel controls and she said it sounded like a spring unwinding i also have a air bag light and pretentioner warning now my quetion i think it the clock spring my lap top wont talk to the steering wheel says no comms stalks are all still working can you replace the clockspring or is it every think so far only place i can get it it from citroen direct and it like £500 pounds
- x 1485
Re: citroen c4 piccasso add blue 1.6 2015 mk 2? clock spring
Welcome along
These are all in one units sadly - Citroen have been using this system for over 20 years. Early ones were a bit unreliable, but there are few issues with more modern ones - appears you have been unlucky... you should be able to get a used one. You may need a diag computer to recalibrate the steering angle sensor.
- x 6956
Certainly will need to recalibrate it if the unit is removed or replaced.
