Door mirrors
Paxo
Door mirrors
Unread post by Paxo »
Just bought a 2014 3008. The door mirrors never folded when locking. The other day was adjusting mirrors when noticed when adjuster is set in the middle and pulled back both mirrors twitch as though trying to fold. Also this happens when locking and unlocking. This affects both door mirrors. Question is have they been deactivated or have both motors gone ( seems strange both going together) . You hear the motors as though engaging aswell.
Sloppysod
x 394
Re: Door mirrors
Unread post by Sloppysod »
I would have thought that if they have been deactivated then they wouldn't move at all, not even "twitch". So I think you can assume that both motors/mechanisms are jammed.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6957
Re: Door mirrors
Lets' have your VIN and I can see if they are fitted with electric fold back option. Please post your VIN in full without spaces - it will be automatically masked from public view
after submitting your post & will only be visible to staff.
Paxo
Re: Door mirrors
Thanks for reply Stu. Well it looks like I'll be stripping the mirrors down.
x 6957
Re: Door mirrors
I can't see this being the case if it's affecting both mirrors - highly unlikely these will both go at the same time. If you have electric fold back fitted, then there's likely to be another issue, like the wiring at the driver's door aperture.
This is the weak spot from the door constantly being opened and closed and often causes a break / short to one of the mirror functions and as the driver's side controls the passenger side that could be why they are both not working.
The other culprit is the driver's door control pad itself - or more specifically the wiring connector blocks underneath. Door closing / slamming can cause these to work loose. Ask me how I know. Taking the door card off and checking that the connectors are secure can fix this - assuming this is the issue.
