pejo 207 1.6 hdi Stalling problem
metehan061
Hello gentlemen, I am the owner of a Pejo 207 1.6 HDI 2009 model vehicle. My vehicle stalls while driving, and when I wait a while and start, it starts. There is no error when connected to the computer. I replaced my vehicle's diesel pump sensor, rail sensor and crank sensor, but the problem continues. The problem happens a few times a week or once or twice a month. Is there anyone experiencing such a problem? What could be the cause of the problem? I need your help.
- x 6945
Re: pejo 207 1.6 hdi Stalling problem
You need a proper diagnostic done and provide us with the fault codes before anyone can give you any informed guidance. It could be anything from electrics, a fuel or air system problem, blockage or something else - and will be total guesswork without getting the codes first.
When you have the full diagnostic codes, put them up here with your VIN.
metehan061
error codes are as follows: p1351, p1462, p1166, 05ff VIN: VF3**************[VIN obfuscated, can be read by forum staff]
- x 6945
You can forget the P1351 for now - that refers to the glow plugs or glow plug heater, which won't affect the issues you're having.
| Fault Code: | P1462 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: | - |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P1166 |
| Symptoms: |
| Suspect Areas: |
metehan061
It was raining a while ago. When the rain stopped, I went to my car and noticed that the bottom of the fuse box under the hood was wet. The cables were wet. Will the vehicle stall for this reason?
- x 6945
Well water and electronics don't mix, so I'd make sure you don't have any water inside the fusebox or on any of the ECUs or electrical equipment. But I doubt this will be the cause of the faults above which are quite specific.
