Help - I need a sump urgently
morgaine
Just got into work and got told that my car was leaking oil - went out to it and there is no oil in the car and about 5 gallons on the floor under it.
My local garage told me I am looking at £270 fitted.
Please please please does anyone have a cheap sump going for a 1995 Xantia Turbo Diesel (non aircon)?
tomsheppard
Kowalski
morgaine
tomsheppard
bernie
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by morgaine</i>
With 5 gallons on the floor There is probably another 4 cars with holed sumps[:D]
As Tom says don't panic
prm
As a temporary measure -- Plastic Padding make an oil and fuel resistant epoxy filler called Leak Fix - about £3.
If its just one or two holes, remove the sump and Set 3/16 long stem ali rivets with this filler as an internal sealer.
Even used rivets without removing the sump --yuck. Used a drill, to best part 9/10ths through, punched remainder to keep swarf out . Not the most ideal repair !!
With that amount of liquid on the floor are you sure its not the tank !!!
R
R
Kowalski
tomsheppard
Panjandrum
morgaine
Just got back home on the back of a recovery truck - now the car is jacked up it looks like just one corner is very badly corroded - and the huge oil spill seems to be coming from one hole about 4mm in size!
I'm not sure if it's alloy or cast - I THINK it's cast. The plan of action at the moment is to clean it up, rivet it, then reinforce it with fibreglass or something along those lines. I am going to try to do it with the sump on, if possible. Although that may not be practical!
Does this sound a workable plan? I will swap it at some stage if I can get hold of a second hand one, but from what I've seen today that may take a while.
Thanks for all your help, I was panicking a little this morning it has to be said
bernie
TheWorker
morgaine
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by TheWorker</i>
if your not sure if the sump is steel or alloy just put magnet to it
LOL - believe it or not I couldn't find anything magnetic in the house!
Oiltight for years sounds good. One year would be most acceptable
