Hello, I recently purchased an aftermarket keyless entry module. Can you help me with a BSI diagram? it would be much easier for me to know where to tie the wires than to look for them myself.
Thank you.
Citroen C5 X7 2.0 165
Keyless entry & start system on Citroen C5 X7
- x 6950
Re: Keyless entry & start system on Citroen C5 X7
You'll need to provide your VIN. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
vasivarvari15
- x 6950
There's no 'BSI' diagram as such - only the systems that are linked to it, so in this case I've provided you with the diagrams for the central locking as I think these are what you will require. Note, as said, of the locking systems available, on your car you have the 'Simple' Central locking, so no deadlocking.
I've put up what else there is regarding the fuses for the BSI
With the exception of the wiring codes, most of the component codes are indexed here:
PSA Electrical Diagrams - Wiring & Symbols Codes Index
Simple Central Locking (Layout)
Simple Central Locking (Diagram)
BSI
BSI
vasivarvari15
Thank you very much, I will come back next week with the result.
vasivarvari15
Can you help me with 2 more diagrams? I would need one for the lights and one to see the footbrake signal. Thank you
Cmlafr
- New User
Hello there.
I'm the owner of a C5 X7 ans i'm intending to install a keyless system toi.
I'm intersting by your feedback. wich kit Did you chose ? Did you reach your installation successfull ? Everu advices will be welcome.
Thanks in avance and good Luck to you.
