Berlingo cabin heating goes off when outside temp is below 10°c
Berlingo village
Unread post by Berlingo village »
Hi, when outside temperature gets below 10°C, my Berlingo 2010 1.6 66kW cabin heating fails and it blows cold air. When outside temperature is 10°C or more, heating works fine.
What could be the cause of malfunction? :shock:
Thank you for any idea. :wink:
x 6950
Re: Berlingo cabin heating goes off when outside temp is below 10°c
Are you sure your exterior temp. sensor is working correctly? If it's faulty, it can affect the A/C Climate system operation as these exterior values are used in the calculation of the cabin temperature.
Berlingo village
GiveMeABreak wrote: 19 Sep 2024, 10:20 Are you sure your exterior temp. sensor is working correctly? If it's faulty, it can affect the A/C Climate system operation as these exterior values are used in the calculation of the cabin temperature.
Thank you for your answer - yes, I believe the exterior temp. sensor works OK, because it shows the correct degrees on dashboard display..
Funny thing is, that when external temperature is 10°C or more, hot air is blown into cabin, but as soon as temp. is 9°C or less, warm air flow becomes cold.. :/
I will check that sensor - maybe it has some hidden malfunction..
