bad vibrations
jakeuk
bad vibrations
Unread post by jakeuk »
when my xantia reaches approx 63 mph the passenger side front wheel/corner starts vibrating and dos'nt stop until it reaches about 68 mph its totally smooth before and after right up to 100 mph[:)]
any input would be appreciated
cheers
AndersDK
Unread post by AndersDK »
Wheel balancing (bad/missing) can in fact do this.
jakeuk
Hi anders,just put new brakes in and as far as i can remember the weights were in place will check again cheers.
anyone got any other ideas?
Stuart McB
Unread post by Stuart McB »
Get tyres checked for any miss shape'ness. May be slightly oval that kind of thing.
jakeuk
tyres are fairly evenly worn,was more concerned it might be a suspension problem? can this be ruled out by the fact it only occurs at a certain speed
Kered
Unread post by Kered »
Look for a bulge on tyre wall on inside wall - it happened to me.
James.UK
Unread post by James.UK »
I agree with Anders, sounds like you need your wheels balancing again. They vary with road wear, weights come off etc, most likely is you may not have put your wheels back on the same studs. Thats if you had them done on, not off, the car.
jakeuk
excellent, cheers guys you put my mind at rest as i know what a small job it is to get the wheels checked out & balanced
