Hello
Can you tell me the jobs that Citroen do at each service please.
Also the build spec of a car I just bought.
I am a member and made a donation.
Any further info on the car appreciated.
VIN VF7**************[VIN obfuscated, can be read by forum staff]
THANKS.
Geoff
Service jobs
- x 6945
Re: Service jobs
Geoff - how did you make your donation? Donations of the required minimum for this service (£10) that are made via PayPal using the donation links are automatic and will upgrade your profile, with the appropriate donor status and year info beneath your user name, which will also be in green.
I'm asking as your donor status has not changed. Please reply via Private Message if you prefer, but do not provide any personal info here in the public forum.
knappettg
Re: Service jobs
Oops - embarrassing. I paid c4owners on the day I joined here and confused the two. Apologies.
I have now made my donation via PayPal.
- x 6945
Re: Service jobs
No problems, here's your build sheet Geoff, and Important Servicing info to follow:
Servicing
Click to Zoom
| Vehicle Characteristics | |
| Vehicle family | C4 PICASSO / C4 SPACETOURER (B78) |
| AS/RP N° | 15994 FV 2 0911 |
| Warranty Start Date | 18/09/2020 |
| Engine serial number | 10 TMA3 0068742 |
| OPB | 00KX |
| BER | e2*2007/46*0356*23 |
| P4A | 9835749299 |
| General Information | |
| PRODUCT TYPE | PASSENGER CAR |
| COMMERCIAL MARQUE/COMPONENT TYPE | CITROEN |
| VEHICLE FAMILY | C4 PICASSO / C4 SPACETOURER (B78) |
| SILHOUETTE | ESTATE - LEISURE |
| TRIM LEVEL | UPPER LOW |
| ENGINE | EB2ADTS/EU63 1200 3 CYL PETROL |
| TRANSMISSION | STT TYPE 8-SPEED AUTOMATIC GEARBOX |
| PAINT TYPE | METALLIC LACQUER |
| BODY COLOUR | EVL - PLATINUM GREY PAINT |
| INTERIOR TRIM TYPE | TRIM.FINN VELOUR "1H" |
| UPHOLSTERY COLOUR | "FR" |
| DEFINITION TO FOLLOW | MID-LIFE |
| ENGINE (TYPE) | EB TYPE ENGINE |
| Fuel Supply-Engine | |
| FAN | 2-SPEED FAN 140W AERO COMPACT DYNAMIC FLAP |
| DRIVE TRAIN | INTERNAL COMBUSTION DRIVE TRAIN |
| TANK FILTER | RESERVOIR FILTER INTERIOR |
| STOP AND START | WITH STOP AND START STARTER |
| FUEL SUPPLY | DIRECT EXCHANGER TURBO INJECTION |
| DIESEL FILTER WATER DETECTOR | WITHOUT DIESEL FILTER WATER DETECTOR |
| FUEL | UNLEADED PETROL 95 QUALITY A/B/E/E+ |
| EMISSIONS STANDARD (ENGINE) | EURO 6.3 ENGINE EMISSION CONTROL |
| SPEED SENSOR SIGNAL | FRONT WHEEL SENSOR NON-SIGN RR SIGNED |
| CATALYTIC CONVERTER | CATALYTIC CONVERTER BELOW 50PPM |
| FUEL TANK | FUEL TANK WITHOUT LOCATING TAB |
| COOLING MOTOR | RADIATOR EP28 28DM2 BRAZED ALUMINIUM |
| CRANKCASE GAS CIRCUIT HEATING | W/O HEATER CASING GAS CIRCUIT |
| EOBD SELF-DIAGNOSIS SYSTEM | "EOBD" SELF-DIAGNOSIS |
| DEVICE (ANTIPOLLUTION) | WITHOUT ANTI-POLLUTION DEVICE |
| VEHICLE TECHNICAL DEPOLLUTION | EURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL |
| PARTICLE FILTER | WITH PARTICLE EMISSION FILTER |
| Gearbox Transmission | |
| GEARBOX TYPE | ATN8 TYPE GEARBOX |
| WHEEL STYLE | CITROEN 17 INCH ALLOY WHEEL |
| CLUTCH | WITHOUT CLUTCH |
| RIM/TYRE SIZE | 17 INCH TYRE FITMENT |
| TYRE (SIZE, TYPE) | 205/55 R17 95V REINFORCED TYRE |
| WHEEL (TYPE) | ALLOY WHEEL ASSEMBLY 1 |
| INFLATION PRESSURE LOSS INDICATOR | INDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION |
| Suspension-Steering-Brakes | |
| BRAKE ASSOCIATED VARIANT | ESP BOSCH 9.1 |
| STEERING (OPERATION) | LOW POWER DOUBLE PINION ELECTRIC POWER STEERING |
| REAR ANTI-ROLL BAR | STIFFNESS 30000 NM/RAD |
| FRONT ANTI-ROLL BAR | FR ANTI-ROLL BAR DIAMETER 23 HOLLOW |
| STEERING WHEEL ANGLE | WITH STEERING ANGLE SENSOR |
| SUSPENSION | LOWERED SUSPENSION |
| SUSPENSION (ARCHITECTURE TYPE) | METAL SUSPENSION |
| DYNAMIC STABILITY CONTROL SYSTEM | ELECTRONIC STABILITY PROGRAM |
| Body Fittings | |
| HANDS FREE ACCESS AND STARTING | FRONT ACCESS + BOOT + HANDS FREE STARTING |
| TOWBAR | WITHOUT TOWBAR |
| HORNS | HORNS-HARMONY |
| AERIAL | FR ROOF+GPS+DIG+INTEGRATED+GSM |
| FINISHER (SELF-ADHESIVE) | GLOSS BLACK REAR SURROUND TRIM |
| WHEEL EMBELLISHER (STYLE) | WITHOUT WHEEL CAP |
| INDICATORS | WITHOUT SIGNALING LIGHTS |
| ADDITIONAL SHIELD (UNDER ENGINE) | W/O ENGINE UNDERSHELDING |
| DRAUGHT EXCLUSION | FR AND RR DOOR AERODYNAMIC SEALING |
| EXT. REARVIEW MIRROR COMP. FUNCTION | DRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY |
| ENGINE BAY SOUNDPROOFING | SOUNDPROOFING FOR BULKHEAD + BONNET + WHEELARCH + POWER TRAIN |
| WINDSCREEN WIPER | 2 SPEED INTERMITTENT+AUTOMATIC CADENCING |
| HEADLAMP WIPER | W/O HEADLAMP WIPER |
| FRONT PANEL BLANK | DOUBLE PILOTED AIR INLET CLOSER |
| ROOF GLASS | WITH ROOF WINDOW |
| BUMPER | BODY COL FR BUMPER+BLACK CAPPING CHR BEAD/BODY COL RR BUMPER |
| NUMBER PLATE | WITHOUT LICENCE PLATE |
| LUGGAGE RACK | MOUNTING WITH ROOF BARS |
| FRONT FOGLAMP | FRONT FOG LIGHTS |
| PANORAMIC VISUAL AID | WITHOUT PANORAMIC VISUAL AID |
| SPARE WHEEL | WITHOUT SPARE WHEEL |
| EXTERIOR ACCESSORIES | BODY-COLOURED EXTERIOR HANDLE |
| GLASS (APPEARANCE) | TINTED + DARK-TINTED WINDOW GLASS |
| WINDOW (TYPE) | LAM ATHERM+ACOUS WINDSCREEN + TOUGH REAR SCREEN |
| Interior Fittings | |
| SEATING ASSOCIATED VARIANT | VARIANT ASSOCIATED WITH HIGH SEAT POSITION |
| DRIVER’S KNEE AIRBAG | WITHOUT DRIVER’S KNEE AIRBAG |
| REAR VIDEO SCREEN | WITHOUT REAR VIDEO SCREEN |
| CHILD OBSERVATION INTERIOR MIRROR | INTERIOR CHILD MONITORING MIRROR |
| AUDIO PACK AUXILIARY SOCKET | 1 USB SOCKET |
| TELEMATIC UNIT | INDEPENDENT TELEMATIC UNIT 3S |
| ANTI-THEFT ALARM | WITH THEFT PROTECTION ALARM |
| REAR HEAD RESTRAINT | REAR HEADREST ADJUSTABLE |
| SUPPLEMENTARY SEAT | 2 PLACES SUPPLEMENT SEPAR SEATS |
| BLIND SPOT DETECTION | WITH BLIND SPOT MONITORING |
| LUGGAGE COVER | LUGGAGE COVER + WINDSTOP |
| FRONT SEATBELT | PYROT PYROTECHNIC SEAT BELT DOUBLE WITH ALARM |
| CLIMATE (AMBIENT TEMP) | HOT OR WIDER TEMPERATE COUNTRY |
| AIR CONDITIONING | WITH HEATER MATRIX |
| SPEED GRADUATIONS | SPEED GRADUATION IN MPH |
| GEAR SELECTOR | GEAR CONTROL AT THE STEERING WHEEL |
| CONSOLE | WITH REMOVABLE CONSOLE |
| DRIVING POSITION | RIGHT HAND DRIVE |
| ADDITIONAL HEATING | WITHOUT ADDITIONNAL HEATING |
| AIR EXTRACTOR | WITHOUT AIR EXTRACTOR |
| MIRROR LINK | WITH MIRROR LINK |
| LOAD SPACE LIGHTING | WITH GLOVEBOX LIGHTING |
| BOOT AND LOAD SPACE LIGHTING | AUTO BOOT LIGHT OR LOAD VOL SWITCH |
| DASHBOARD EQUIPMENT | UPPER PART PEARLESCENT ARDOISE GREY |
| INT. TRIM AND EQUIPMENT VARIATION | CLOTH INTERIOR EQUIPMENT TRIM |
| MISC. INT. LAMPS | LIGHTING BY LEDS |
| WORK TABLE | WITH WORK TABLE |
| LOAD SPACE TRIM | FOAM BOOT MAT + SOUNDPROOFING |
| UNDERSEAT STORAGE | 2 UNDER SEAT STORAGE DRAWERS |
| INSTRUMENT PANEL (CHARACTERISTICS) | DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS |
| DOOR TRIM | DECOR GLOSS VARNISH |
| LOUDSPEAKER | 4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS |
| ADDITIONAL BLOWER | WITH ADDITIONAL PULSE |
| PASSENGER COMPARTMENT SOUNDPROOFING | SOUNDPROOFING FOR BULKHEAD + TUNNEL TOP RANGE |
| FRONT PASSENGER SEAT HEIGHT CONTROL | FRONT ADJUSTMENT PASSENGER SPACER |
| DRIVER SEAT CONTROL | DRIVERS FRT SEAT MANUAL CNTROL |
| FRONT PASSENGER SEAT CONTROL | PASSENGER FRT SEAT MANUAL CNTR |
| DRIVER SEAT ADJUSTMENT | DRIVER’S SEAT TILT BACK ELECTROPN LUMBAR SUPPORT |
| FRONT PASSENGER SEAT ADJUSTMENT | PASSENGER LUMBAR ADJUSTMENT |
| FRONT PASSENGER SEAT FOLDING | WITH FOLD PASS FRONT SEATING |
| FRONT SEAT ARMREST | DRIVER ANT PASSENGER FRONT ARMREST |
| COMPACT DISC | WITHOUT COMPACT DISC |
| STOWAGE BIN | FLAPS IN FLOOR |
| SATELLITE NAVIGATION SYSTEM | WITH NAVIGATION SYSTEM COLOUR SCREEN |
| HEADLAMP BULBS | DISCHARGE BULB |
| REAR WINDOW LIFT | SEQENT CONTR RR WINDOW LIFTER |
| TRAFFIC INFORMATION READER | PREVENTION+CORRECTION OF LATERAL TRAJECTORY |
| DISPLAY | DGT TOUCHSCREEN+12" DFT DISPLAY |
| OIL GAUGE | STD OIL LEVEL INDICATOR |
| FITTING REAR HEAD RESTRAINT | MOUNT 3 REAR HEAD-REST |
| HEATING ELEMENT | NON HEATED SEAT |
| FRONT LATERAL AIRBAG | THORAX SIDE + CURTAIN AIRBAG |
| FOOTWELL LIGHTING | DRIVER’S FOOTWELL + DOOR TRIM PAD LIGHTING |
| ELECTRIC WINDOW (OPERATION) | DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH |
| AIRBAG DEACTIVATION | MANUAL AIRBAG DEACTIVATION |
| COURTESY LAMP | CONTROLS FOR FRONT + REAR DOORS, FRONT + REAR INTERIOR LAMPS |
| HEADLAMP HEIGHT ADJUSTER | REMOTE MANUAL HEADLAMP ADJUSTMENT |
| WIFI | WITH WIFI |
| RADIO RECEIVER | DIGITAL CONNECTED NAVIGATION |
| REFRIGERATION | AUTOMATIC AIR CONDITIONING |
| CRUISE CONTROL | ADAPTIVE CRUISE CONTROL AND SPEED LIMITER |
| INTERIOR REAR VIEW MIRROR | ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR |
| STORAGE (OTHERS) | NET SEAT BACK STORAGE POCKET |
| CARPET COVER | CARPET MAT 1 |
| DRIVER AIRBAG | DRIVERS AIR BAG |
| LOAD SPACE STORAGE | W/O BOOT TIDY |
| TUNER RADIO | MONO RADIO TUNER |
| OBSTACLE DETECTION SYSTEM | FR AND RR RADAR OBSTACLE DETECTORS + RR CAMERA+AUTO PK |
| LATERAL BLINDS | SIDE BLINDS |
| FLOOR MAT | FR + RR MATS |
| EQUALISER AMPLIFIER | WITHOUT EQUALISER AMPLIFIER |
| RADIO FREQUENCY | WESTERN EUROPE RADIO FREQUENCY |
| LOCKING CONTROL | DEADLOCKING + AUTOMATIC LOCKING |
| STEERING WHEEL | LEATHER STEER WHEEL 4 BRANCHS |
| Electrical | |
| LIGHTING OF LAMPS | AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING |
| ALTERNATOR | ALTERNATOR CLASS 15 HEA |
| BATTERY | BATTERY L3 760 70AH EFR 760 EN EF |
| STARTER MOTOR | STOP AND START BY STARTER |
| SPECIAL LIGHTING | FRONT DAY RUNNING LIGHT (DRL) |
| CEN. LOCKING REM CONTROL FREQUENCY | 433.92 MHZ SUPER HETERODYNE |
| MULTIPLEXING | MODIFIED ECONOMY ELECTRICAL ARCHITECTURE |
| Component manufacturers | |
| Miscellaneous | |
| SPECIAL SPECIFICATION | STANDARD |
| CONDENSER (SPECIFICATIONS) | CONDENSER 19,3DM2 THICKNESS 12 |
| VIN PLATE | EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE |
| LABEL | WITHOUT LABEL |
| RADIO HEADPHONE SOCKET | TRIPLE ACCESSORIES SOCKET |
| TRAFFIC SIDE | DRIVING ON THE LEFT-HAND SIDE |
| SIDE IMPACTS | DOOR WITHOUT REINFORCEMENT |
| REFRIGERANT | AIRCON FLUID 1234 YF |
| EMERGENCY EQUIPMENT | PUNCTURE REPAIR KIT |
| SURFACE CONDITIONS | GOOD TERRAIN |
Servicing
Click to Zoom
