Hi all
Ok a couple days ago got back to the car and my key fob would not open the car, my other half had her fob which worked,so at home I have put a new battery in my fob it still will not open or lock the car and will not start the car unless I put the fob into the dash,has anybody got a solution to this .
2013 DS5 Fob Problem
- x 6950
Re: 2013 DS5 Fob Problem
try reinitialising it, but if that is not working, then if it's been dropped, it could of damaged things internally.
Procedure is incorporated into the BSI Reset / Battery Disconnect / Reconnect Procedure
