208 erratic ignition timing and low power.
Tomostrash
Hi we've got a 208 1.0l 3cyl petrol that's extremely flat on acceleration. Plugs and coils are new, the map sensor is also new. We've got some like readings and the ignition advance can go -10 to +10 degrees instantly. Any pointers would be appreciated.
Reason: Moved to Peugeot Technical Forum
- x 6957
Re: 208 erratic ignition timing and low power.
Really needs a diagnostic, then put up the codes here with the VIN.
Tomostrash
I have but there's no codes
OnlinePaul-R
- x 1942
What are you using to read for error codes?
