Xantia 1.9TD (1994) HAND BRAKE cable length.....RIGHT side.
Anyone know the correct length....I am getting 1262mm or 1346mm
- x 1998
- x 8343
Re: Xantia 1.9TD (1994) HAND BRAKE cable length
There's two lengths Alasdair, one for the 'small' engined models with the BE3/HP14 Gearbox and one for the 'large' engined models (2.1TD, 2.0TCT, V6 and 110HDi) with the ML5/HP20 gearbox. The longer of the two is for the latter (big engined) models...
- x 1998
More confused now.....there seems to be more choices than that and this post throws me even more....
https://www.frenchcarforum.co.uk/forum/ ... 13#p328813
Reason: Tidied up link
- x 1446
I was under the impression that there was only one length of RH cable for all Xantii. I don't have a spare so can't measure the length.
[edit] I am pretty sure that the RH cable is the long one, 1330mm.
- x 1998
OK....1330mm one ordered........cheers chaps
Brand Quinton Hazell
Placement on Vehicle Right Front
Length 1330 mm
Length 1330 mm
