warning lights c4 grand picasso
jdix1966
hi everyone i have a problem with my 2014 c4 grand picasso getting fault code p0809 and u1208 i have replaced clutch master cylinder twice thort first one was faulty but problem still there but strange thing is if i put in reverse manual box push start button i get no warning message to check engine and parking brake and i can then clear faults but as soon as i take out of reverse they come back when i check data for clutch pedal it says released even when pushed down percentage reades 100 percent when fully depressed has anybody come across this before i also replaced reverse switch checked the 3 wiers on switch for continuity all ok 5v ref there and ground is ok 5v on signal wire hope someone can help thanks
- x 6957
Re: warning lights c4 grand picasso
Best to provide your VIN so we know exactly what engine and equipment you have. U1208 is a comms / data network fault as is a generic code that can relate to different systems - so we need the context in which the fault appears - under which system does the fault appear? Gearbox, Engine, ESP, etc.
Considering the other behaviour you mention, you may be focussing on the mechanical and not the other potential issues like the electrics or connectors, which is what the U1208 code may be trying to tell you.
| Fault Code: | P0809 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
jdix1966
ABS or ESP -- ESP90//
Engine ECU -- HDI_SID807_BR2 ( 1 DTC )
DTC
Description
P0809
Clutch master cylinder position measurement -- Signal
implausible
Status
Permanent fault
ABS or ESP -- ESP90 ( 1 DTC )
DTC
Description
U1208:81
Inter-systems CAN (Engine ECU) -- Data received invalid
Status
Permanent
DTC
Description
P0809
implausible
Status
Permanent fault
DTC
Description
U1208:81
Status
Permanent
jdix1966
- x 6957
| Fault Code: | U1208 81 |
| Symptoms: |
| Suspect Areas: |
jdix1966
Thanks for info marc will check the. Suspect areas i was just a bit confused about the when in reverse every thing was normal
maciejwrc
Hi all. I have a question for jdix1966. I have the same symptoms and fault codes as you. The clutch master cylinder has been replaced. What was the problem in your case?
Yusef
Hello, I have the same pb I replace all components but start only in reverse. Please can you tell me what was your problem please. Thanks for all.
Yusef
Nobody to help me
- x 1488
You will need to get it on a diagnostic machine to see if there are codes present, and then what live data is present. I can't really think why it would start in reverse but not neutral or a forward gear - unless the reverse light is providing a ground path that is not otherwise there.
Yusef
Thanks for your help Richard., I am going to see that now.
Yusef
Ok with diagbox I clear the fault and I reset clutch master cylinder, now all is OK thank you.
