On / off button not working
Ray123
Hi, the on / off button of my Peugeot partner 2017 is not working. The display is working, so are the other buttons on the radio which makes me think it cannot be the fuse. If I twist the same button the volume change shows up on the screen, so it is just on / off press that is not working. Any ideas on how to solve appreciated!
- x 6957
Re: On / off button not working
Can't think why this would be a problem, I've never turned it on or off with the button as it just comes on with the ignition and off again. I just lower the volume if I don't want to hear it. But if your has stopped working with the push, then it's probably the button mechanism that has failed, so I wouldn't advice pressing it on or off anymore - as if it gets stuck in the off next time, you've had it. Best to just lower the volume in future and leave it on.
- x 1942
Do you have any duplicate controls on the steering wheel or a separate stalk?
