Witam wszystkich jestem nowy na tej grupie. Poszuka?em troch? w internecie i wydaje mi si? ?e jest to dosy? dobra grupa dyskusyjna.
Mam problem z autem
C4 Picasso 2014
Po ulewie zacz??o auto troch? by? dziwne. Wycieraczka tylna sama si? w??cza?a nie by?o reakcji na pilota przy zamykaniu i nie chcia? odpali? . Po wymianie akumulatora auto odpali?o jakby wszystko wróci?o ale nie dzia?a nawiew . Wogole nie dmucha , czy na automacie czy r?cznym ustawieniu odpowiedniej pr?dko?ci wentylatora na panelu to nic si? nie za??cza . Mechanicy sprawdzili podobno silnik od dmuchawy dzia?a na krótko , rezystor mówili ?e te? wygl?da na dobry . Mia? kto? mo?e z Pa?stwa podobny problem ?? Pozdrawiam
C4 Picasso 2014 Brak nawiewu
- x 5654
Re: C4 Picasso 2014 Brak nawiewu
Please post in English as most of our members only speak English and will not be able to help you.
You can use Google Translate or DeepL to translate your text but of course there may be errors.
Prosimy o publikowanie w j?zyku angielskim, poniewa? wi?kszo?? naszych cz?onków mówi tylko po angielsku i nie b?dzie w stanie Ci pomóc.
Mo?esz u?y? T?umacza Google lub DeepL, aby przet?umaczy? swój tekst, ale oczywi?cie mog? pojawi? si? b??dy.
Google translation of your question:-
Hello everyone, I'm new to this group. I did some searching on the internet and it seems to me that this is quite a good discussion group.
I have a problem with my car
C4 Picasso 2014
After a downpour, the car started acting a bit strange. The rear wiper turned on by itself, there was no reaction to the remote control when closing it and it wouldn't start. After replacing the battery, the car started as if everything had returned but the blower doesn't work. It doesn't blow at all, whether on automatic or manual setting of the appropriate fan speed on the panel, nothing turns on. The mechanics checked, apparently the blower motor works for a short time, the resistor said that it also looks good. Has anyone had a similar problem? Best regards
C4 Picasso 2014
