in my 2.7 HDI 2005, i recently started experiencing hesitation and missing during acceleration, espeially from low speed. Not surprisingly, I got a P0404 showing the front EGR as blocked. The unit was replaced (with an original Valeo unit), but the change did not have any effect. I also had error codes for airflow, which I'm fairly sure is associated wit the EGR. To be sure, I swapped my airfilter box with airflow sensors from a C6 with no errors, this did not change anything.
When replacing the EGR, does it have to be initalised from Lexia? I do have Lexia, and just barely started to look into it, but does anyone know of any guidance for initialisation and function testing?
Co-incidentally, befor theis happened, I had to replace the front turbo vane actuator. I can't see this co-relates in any way to the EGR problem? The turbo vane error code is gone, and the symptoms different (The actuator failure resulted in occational limp-mode that was rectified by stopping and starting the engine).
Kind regards,
Thore
EGR replacement - no cure
ThoreT
- (Donor 2026)
- x 6945
Re: EGR replacement - no cure
Hi Thore
Unfortunately Citroen don't provide any detailed info on this fault for the 2.7 HDi DT17 with Siemens EMS.
In case it provides some pointers (with the caveat that this is for a DV5 engine), this is what is stated, so may or may not be relevant or useful... also this has the suffix of 19 to the main P0404 code, so again, may be entirely different and applies to Bosch.
| Fault Code: | P0404 19 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
ThoreT
- (Donor 2026)
Marc,
thank you.... the correct code is P0404. It reads as Front EGR Blocked
- x 6945
oops a typo, I'll update my post above shortly
