I'm going to kill that car soon
ItDontGo
Just calming down after driving my mum's Xsara. Everytime I have to use that thing it makes me mad. Really mad. Its an awful bloody thing. There is nothing right about it but one of the worst things is the 1000/4000 rpm switch that takes the place of the throttle on a decent car. I think this must be faulty because surely somebody at Citroen didn't think it was actually nice like that.
When you try to heel and toe it all goes wrong (which is why I get angry with it) because it has almost no response for a short period of time and then suddenly the revs shoot up really suddenly. Its a similar story when you start to press the throttle to drive away so you shoot off all of a sudden with no warning as to when it is going to happen.
One thing I did notice is that if you give it a bit of stick it starts to cut out when it should be idling and also if you take the fuel cap off there's a gush as air is sucked into the tank. I assume this is at the route of the problem so what might cause this vacuum in the tank?
Even if that was sorted it would still be an 'orrible motor. Afterall thats not going to fix the clutch, the brakes or the steering is it! [:(!] [:(!]
By the way its a 1.4 8v.
steveallmond
Stuart McB
ItDontGo
Stuart McB
ItDontGo
Stuart McB
The tank should have a breather hose along side the main filler hose. This may be blocked by c**p. If so you get an air lock in the tank. As for a MAP sensor. If you can locate and remove it they can be cleaned out with a littler brake cleaner(not carb as this is too corrosive) and by leaving in a warm are for the oil to drain out on to some paper towel. Basically the oil vapours settle on the diaphram in the sensor and stop it working fully when cold. As the oil warms you get a better and better response from the sensor. You get a sort of stalling but onlu every now and again, no pattern to it, low ideling, revs going up and down but other wise the car runs fine.
ItDontGo
If I was mad when I wrote this then that was nothing compared to how mad I am now!
Yesterday on my way home from a friends funeral the thing broke down on me. I cant believe it its only 2.5 years old. What are Citroen playing at these days?
If you're interested it was the ignition coils.
And even worse it obviously wasn't too happy about me running the air con all day the previous day and when I got in it yesterday it absolutely stunk of damp. It must have a blocked drain tube.
I wish I'd have gone in my AX!
On a lighter note does anybody want to buy a mint condition Y-reg Citroen Xsara? We've never had any trouble with it - runs like a dream! [:)] Father McGuire from our local parish never had any trouble wih it when he owned it either. And when we took it back to France the other week to get Citroen to do a full 35000 mile check up they said it was the best example they have ever seen [:)]
James.UK
Stuart McB
ItDontGo
The BX dont go because I decided to go to uni and as I have said before it can smell my money. So I thought best to get a cheaper car whilst I'm an impoverished student.
Now I have finished, the reason it still 'dont go' is because I'm a lazy git and cant be bothered getting an MOT for it. Plus I love my AX. Plus it annoys my neighbours that I have a SORNed car on my drive. Hehe. But they are too polite to mention it. Hehehehe.
CITMAN
Must admit that I have often thought about replacing my old 95 zx 1.4i with an xsara vts when I was at university. But know ive got my degree and i know it sounds stupid but I cant part with it. So ill either run it until it goes pop. Or declare SORN and keep it on the drive and annoy the neighbours even more he he he he he he he he he he!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! and get the vts.
mark_sp
davek-uk
Kowalski
