Build sheeet for Mme's C4
Vic Evans
x 168
Unread post by Vic Evans »
Any chance of a build sheet for the C4? I believe you have the VIN no. Absolutely no rush.
The car seems to have most of the bells & whistles but lacks things to do with the door mirrors ie they don't fold in when ignition turned off & can't be programmed to turn down for parking when reverse is engaged.
It's probably not got these features & no big deal. Just be nice to be sure it's not dim operator error after 10 years of ownership. :lol:
x 6955
Re: Build sheeet for Mme's C4
Here you go:
Vehicle Characteristics
Vehicle familyC4 (B7)
AS/RP N°13696 88 1 0347
Warranty Start Date13/06/2014
Engine serial number10 JBEE 3107004
OPB0004
BERe2*2007/46*0040*17
P4A9802578199
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYC4 (B7)
SILHOUETTE5 DOOR SALOON
TRIM LEVELMEDIUM MEDIUM
ENGINETURBO DIESEL DV6DTED
TRANSMISSIONBVM5
PAINT TYPEMETALLIC LACQUER
BODY COLOURKTP - SHARK GREY PAINT
INTERIOR TRIM TYPEW&W HERMITAGE G142 + W&W OMNI REPS "4X"
UPHOLSTERY COLOUR"FX"
GEARBOX (CHARACTERISTICS)BE4-5L MANUAL GEARBOX
DEFINITION TO FOLLOWINITIALE RANGE
ENGINE (TYPE)DV TYPE ENGINE
ROOF (EXT. ASPECT)BODY COLOUR ROOF
OTHER BADGE, " MISC. "WITHOUT FULLER BADGE
Fuel Supply-Engine
FUEL SUPPLYDIRECT EXCHANGE TURBO INJECTION
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
FUELDIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE)EURO 5 L6 UPPER ENGINE EMISSION CONTROL
CAPACITY1600 CM3
CATALYTIC CONVERTERCATALYTIC CONVERTER BELOW 50PPM
OIL COOLERMNTG WATER/OIL EXCHANGER ON ENGINE
FUEL TANKFUEL TANK WITH LOCATING TAB
OPTIMISATION OF VEHICLE’S CONSUMPTIONOPTIMISE
COOLING MOTORRADIATOR TH : 27 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATINGWITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE)68 KW - 230 NM
EOBD SELF-DIAGNOSIS SYSTEM"EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
DEVICE (ANTIPOLLUTION)"EGR" EXHAUST GAS RECIRCULATION + EXCHANGER
VEHICLE TECHNICAL DEPOLLUTIONTECHNICAL VEHICLE EMISSION CONTROL EURO 5
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
FAN1 AERO 2-SPEED 140W FAN WITHOUT SCOOP
FUEL VAPOUR RETRIEVALWITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANTMOUNTING BOSCH
TANK FILTERRESERVOIR FILTER INTERIOR
STOP AND STARTWITHOUT STOP AND START
Gearbox Transmission
TRANSMISSIONBVM5
FINAL DRIVE RATIOREAR AXLE HYPOID GEARSET 19 X 70
WHEEL STYLE16-INCH "DARWIN" ALLOY WHEEL B75
CLUTCHHYDRAULIC CLUTCH
DIFFERENTIAL (GEARBOX)DIFFERENTIAL 84
RIM/TYRE SIZE16 INCH TYRE FITMENT
TYRE (SIZE, TYPE)TYRE 205/55 R16 91V NON REINFORCED
WHEELS FITTED7" RIM ROAD WHEELS
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATORWITHOUT TYRE DEFLATION INDICATOR
GEARBOX TYPEGEARBOX BE4R
Suspension-Steering-Brakes
REAR ANTI-ROLL BARREAR ANTI-ROLL BAR DIAM 25
FRONT ANTI-ROLL BARFRONT ANTI-ROLL BAR DIAM 22
BRAKE TYPEVENTILATED FRONT DISCS/REAR DISCS
POWER STEERING FLUID COOLING SYSTEMWITHOUT POWER STEERING OIL COOLING
SUSPENSIONNORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANT8 1 BOSCH ESP
PEDAL BRACKET (TYPE)PEDAL STANDARD
Body Fittings
TOWBARWITHOUT TOWBAR
HORNSHORN STANDARD
AERIALROOF AERIAL + GPS + INTEGRATED
REAR SPOILERASSEMBLY WITH REAR SPOILER
DECORATION (PAINTED)SOLID COLOUR DECOR
SIDE MOULDINGS (TYPE)WITHOUT LATERAL PROTECTORS
SIDE MOULDINGS (DIMENSION)WITHOUT LATERAL PROTECTORS
WHEEL EMBELLISHER (STYLE)WITHOUT WHEEL CAP
INDICATORSSIDE MARKER LIGHTS
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. LOAD RETENTION RING (ATTACHMENT)BOAT EXT LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTIONEXT MIRROR MANUAL-FOLD BACK
SPLASH SHIELDSTANDARD MUD GUARD
EXHAUST TAILPIPE TRIMW/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFINGUNDERBONNET + BULKHEAD SOUNDPROOFING
WINDSCREEN WIPERINTERMITT AUTO FR WIPER BLADE + WATER LEVEL
HEADLAMP WIPERW/O HEADLAMP WIPER
REAR SCREEN WIPER (OPERATION)AUTO INTERMITTENT RR WIPER IN REVERSE GEAR
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
ROOF GLASSWITHOUT ROOF WINDOW
BUMPERBODY COLOUR FRONT/REAR BUMPER
MUDFLAPWITHOUT REAR MUDGUARD
NUMBER PLATEWITHOUT LICENCE PLATE
FRONT FOGLAMPFOG LAMPS WITH CORNERING LIGHT
SPARE WHEELSTEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIESBODY COLOUR EXT HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)CURVED EXTERIOR MIRROR GLASS
BUMPER TRIMBUMPER WITHOUT TRIMMING
GLASS (APPEARANCE)TINTED + DARK-TINTED RR WINDOW GLASS
REAR QUARTER WINDOW (TYPE)FIXED REAR QTR GLASS
WINDOW (TYPE)ACOUSTIC LAMINATED WINDSCREEN+TOUGHENED RR SCREEN
EXTERIOR STYLING PACKCOLOUR DYED DECOR (DDY07)+CHROME WINDOW TRIM (DGV04)+TINTED+DARK-TINTED REAR WINDOW (DVD10)
RADIO-INFORMATION-COMMUNICATION PACKWITH HANDS-FREE TELEPHONE KIT (DDO01) + eMyWay (DRCT6) + 1 JACK SOCKET + USB (DYM04)
HANDS FREE ACCESS AND STARTINGWITHOUT HANDS-FREE ACCESS/STARTING
Interior Fittings
ANTI-THEFT ALARMWITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTERWITHOUT CIGAR-LIGHTER
REAR HEAD RESTRAINTREAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINTJOINTED FRONT HEADREST
REAR SEATREAR BENCH SEAT SINGLE CUSHION SEPARATE SEAT BACKS
BLIND SPOT DETECTIONWITHOUT BLIND SPOT MONITORING
REAR SEAT ARMRESTWITHOUT RR SEAT ARMREST
LUGGAGE COVERSHELF
REAR SEATBELT3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING
FRONT SEATBELTPYROTECHNIC SEAT BELT WITH ALARM
CLIMATE (AMBIENT TEMP)COLD COUNTRIES
AIR CONDITIONINGWITH HEATER MATRIX
CHILD LOCKMANUAL REAR CHILD LOCK
SPEED GRADUATIONSSPEED GRADUATION IN KM/H
CONSOLELONG CONSOLE
DRIVING POSITIONLEFT-HAND DRIVE
ADDITIONAL HEATINGAUTOMATIC ADDITIONAL HEATING
BOOT AND LOAD SPACE LIGHTINGAUTO BOOT LIGHT AND LOAD VOL SWITCH
DASHBOARD EQUIPMENTSTANDARD FASCIA + INJECTION MOULDED BASE
MISC. INT. LAMPSLC FR/RR WITH LAMPS WITHOUT AMB LED WITHOUT AMB LGTS
LOAD SPACE TRIMBOOT CARPET MAT
UNDERSEAT STORAGE1 UNDER SEAT STORAGE DRAWER
INSTRUMENT PANEL (CHARACTERISTICS)CROWN INSTR PANEL, CUSTOMISABLE
DOOR TRIMSOFT HOT ALU DECOR
CHILD SEAT ANCHORING POINTSWITHOUT CHILD SEAT MOUNTING WITH ISO RR
LOUDSPEAKER4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
RADIO CONTROLSREMOTE RADIO CONTROL
PASSENGER COMPARTMENT SOUNDPROOFINGBULKHEAD S’PROOF 5.5KG + TAILGATE + QUARTER PANEL
FRONT PASSENGER SEAT HEIGHT CONTROLPASSENGER BOOSTER PARALLEL + FRONT ADJUSTMENT
DRIVER SEAT CONTROLDRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROLPASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENTDRIVER’S LUMBAR SUPPORT
FRONT PASSENGER SEAT ADJUSTMENTPASSENGER’S LUMBAR SUPPORT
FRONT SEAT ARMRESTFRONT SEAT CENTRAL ARMREST
EXTERIOR TEMP. INDICATOREXT TEMP INDICATOR
SATELLITE NAVIGATION SYSTEMWITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBSHALOGEN BULB
REAR WINDOW LIFTSEQENT CONTR RR WINDOW LIFTER
TRAFFIC INFORMATION READERWITHOUT LATERAL TRAJECTORY MONITORING
PASSENGER’S WINDOW LIFTSEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
DISPLAYDISPLAY DG4
COURTESY MIRRORDRIV OCCULT+PASS OCCULT W/O LIGHT
FOOTRESTFOOTREST WTH DRIVER + PASSENGER
OIL GAUGEW/O OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINTMOUNT 3 REAR HEAD-REST
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGTHORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTINGWITHOUT DOOR SILL LIGHTING
ELECTRIC WINDOW (OPERATION)DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH
ON-BOARD COMPUTERCOMPUTER
EQUIPMENT PACKWITHOUT DRIVING SCHOOL EQUIPMENT PACK
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE)CHROME DOOR HANDLE + NEUTRAL TRIM
HEADLAMP HEIGHT ADJUSTERREMOTE MANUAL HEADLAMP ADJUSTMENT
DIRECTIONAL HEADLAMPWITHOUT DIRECTIONAL LIGHTS
FRONT SEAT GUARDWITHOUT CAB PROTECTION PANEL
FRONT SUN VISORDRIVER + PASSENGER SUN VISOR WITHOUT INSCRIPTION
STORAGE (DRIVING POSITION)STORAGE COMPARTMENT + BLACK HANDLE
RADIO RECEIVER’RT6’ AUDIO/TELEPHONE REMOTE DISPLAY
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLPROGRAMMABLE CRUISE CONTROL AND SPEED LIMITER
INTERIOR REAR VIEW MIRRORELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
STORAGE (OTHERS)STANDARD STORAGE COMPARTMENT + SEAT BACK POCKETS
CARPET COVERW/O CARPETMAT
LOAD SPACE STORAGEBOOT LATERAL STRAP + NET
CARPETNEEDLED CARPET DILOUR F550
TUNER RADIODUAL RADIO TUNER
COOLANT LEVEL WARNING LAMPNO WATER LEVEL WARNING
OBSTACLE DETECTION SYSTEMWITHOUT OBSTACLE DETECTOR
TRIM ADAPTATIONLEATHER KNOB + PLASTIC GAITER
FLOOR MATW/O CARPETMAT
EQUALISER AMPLIFIERWITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCYWESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROLNORMAL + AUTOMATIC LOCKING
STEERING WHEEL4-SPOKE LEATHER STEERING WHEEL CHROMED DECOR
AUDIO PACK AUXILIARY SOCKET1 JACK SOCKET + USB
TELEMATIC UNITWITHOUT TELEMATIC UNIT
Electrical
ALTERNATORALTERNATOR 150 AMP
HORNSHORN STANDARD
BATTERYBATTERY L3 720 LDC**************[VIN obfuscated, can be read by forum staff](L3 720 70AH EF 720 EN)
STARTER MOTORCLASS 6 STARTER MOTOR
SPECIAL LIGHTINGDAYLIGHT RUNNING LIGHTS
CEN. LOCKING REM CONTROL FREQUENCYLOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
BATTERY CHARGE MEASUREMENTWITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF LIGHTS
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABELWITHOUT LABEL
RADIO HEADPHONE SOCKETWITHOUT ACCESSORIES SOCKET
TRAFFIC SIDEDRIVING ON THE RIGHT-HAND SIDE
SIDE IMPACTSDOOR WITHOUT REINFORCEMENT
SET OF KEYS1 HF PLIP KEY + 1 SINGLE MAIN KEY
EMERGENCY EQUIPMENTW/O HELP EQUIPMENT
SURFACE CONDITIONSGOOD TERRAIN
SPEED MONITORINGWITHOUT SPEED CHECK
ADDITIONAL TYPE APPROVAL PLATEW/O ADDIT HOMOLOGATION PLATE
Vic Evans
x 168
Many thanks Marc
Brilliant service as usual.
I showed this to Mme & she said " yeah, so?" :roll:
Seems like I wasn't as dim as I thought re mirrors :)
vic
x 6955
Yes, manual foldback only on this and as far as the dipping in reverse goes, that function was removed on a lot of vehicles due to some EU regs, so if you ever did have it and had the BSI software updated, it was disabled. They did this on my C5 X7 after an update, and I re-enabled it back myself. Infuriating and ridiculous interference.
