Hello Fam,
I just got this car last week and the heating system can't heat up the car, the passenger side is a bit warm but driver side was not working at all. At first when I turned on the heating in less than 2 minutes I started the car, It started jerking and showed Engine repair Icon. I switched off and start again and it worked smoothly but the engine iconis still there. Please any idea of what happened to it.
Heating Issue with my DS4 2011
- x 1499
Re: Heating Issue with my DS4 2011
Heating issue might be a blocked matrix, but could also be a problem with the water pump or thermostat - is there a temp gauge and what was it saying?
The engine repair is probably something else - you will need to get the codes read and see what is at fault. What engine is in it?
