Citroen Relay AIT Sensor - Fault Code P0113
g-hack86
Unread post by g-hack86 »
My Citroen Relay (18 plate) was sluggish up hills last weekend and towards the end of the 2 hour journey, the EM light came on. Plugged in an OBDII reader and got fault code P0113, which is Intake Air Temperature Sensor 1 Circuit High Bank 1. (VIN: VF7**************[VIN obfuscated, can be read by forum staff])
I cleared the code this morning and drove for an hour to see if it would reproduce, but all seemed to run fine.
A few questions
1. What should the Air Intake Temperature range be when the outside temp is around 12 degrees?
2. Is the AIT part of the MAF sensor on the Relay?
3. If not, where is it located?
Thanks,
Graham
PaulC5
x 696
Re: Citroen Relay AIT Sensor - Fault Code P0113
Unread post by PaulC5 »
The AIT should be the outside temp before the first start of the day but then will go up a bit with heat from the engine so maybe now about 15°C rising to 30 or 40°C.
