Dear guys. I got frequently this error (P0131). The car starts active regeneration as soon as weight of soot reaches 1 g/l so makes every 150 ton200 km active regeneration. As soon as starts active regeneration the P0131 occures again as i clear the fault before.
Do you think this frequent active regenerations are related to faulty oxygen sensor? I bought a Topran oxygen sensor instead oem product but not changes yet. Very difficult location on 2.0 HDI.
2.0 HDI 165 FAP - P0131 Oxygen Sensor Fault
bahcekapili
- x 9
bahcekapili
- x 9
Re: 2.0 HDI 165 FAP - P0131 Oxygen Sensor Fault
Ok. I changed oxygen sensor with new Topran made one. Now we have another problem. At 100 km weight of soot reaches to 5 g/l
Is there a learning process of new sensor?
- x 6946
Hi, the faults should be read and cleared after the replacement, but there is no programming required for the replacement of the Emissions oxygen sensor on this vehicle. However it is not only the sensor that can cause this fault which is a short circuit:
So I would check the electrical connection carefully, especially the plugs and pins, wiring sleeves for wear or poor connections.
| Fault Code: | P0131 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: | - |
| Symptoms: |
| Suspect Areas: |
bahcekapili
- x 9
Thanks so much. With the new sensor i got the p0171 code. What is about it?
- x 6946
| Fault Code: | P0171 |
| Symptoms: |
| Suspect Areas: |
So again this could be an electrical / supply / earth issue.
bahcekapili
- x 9
Problem solved with original Oxygen sensor. Now no problems no codes. The regeneration process is now ok. With 3rd party oxygen sensor (Topran made) active regeneration intervals was about 100 - 150 km and now with same conditions it is 400 - 450 km. I remember a member said all sensors except for originals are junk. It is right.
