I need some help please . I own a 2016 Relay fittted with the 2.0 dw10fud motor. The cambelt failed before I purchased it. So I replaced the the lifters,followers,cams,chain, belt etc and it ran perfect for a few months.. then the cam sprocket lost/snapped the woodruff and damaged lifters and rockers again
2016 Relay 2.0 cambelt failure and subsequent non start
captainchaos
Hi all.
.. so I’ve repaired it all again but it refuses to start .. it’ll run off of brake cleaner with no noises etc, but will not fire the injectors(plenty of diesel upto them) no signal/pulse to them from ecu (checked with scope).. it has a spurious fault code of p16e-94 but can’t really find an accurate description of the fault code anywhere (I believe it’s to do with fuel pressure being high in rail cause injectors not firing
). Tia for any help.
