Peugeot RCZ RT6 problems
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
CreativeName
Unread post by CreativeName »
Hello, I have a 2014 Peugeot RCZ facelift and a few weeks ago the screen, radio, ... Everything stopped working. Also the cd slot made noises like it was trying to pull a cd in. After some research I found it was the sd card fault and removed the radio and the sd card and bought a new one and put it all back together. Since the sd card doesn't have any software on it I downloaded an ISO file for 2.86 RT6 software and burned it to a new CD. When I put the cd in the slot it spun for a minute and then just came back out. Tried it several times and the result is always the same. I've also tried to extract the iso files to a USB which I formatted to FAT32, but no luck with that either. Although when I put the usb in the cd slot noises stop. Can anyone help me out on this one? Thanks in advance!
x 6957
Re: Peugeot RCZ RT6 problems
There's a guide on replacing the MocroSDS card on this Sub-Forum.
If you followed that, and tried a BSI Reset / Battery Disconnect / Reconnect Procedure to see if that resets the RT6 (which may also trigger the firmware update) and it is not working, then it may be the motherboard of the RT6.
