Hi all,
I have a Citroen Spacetourer 2017 passenger van which keeps returning the code B1805:62 Starter Fault - Consistency. The issue is that this code seems to prevent the vehicle from doing its own DPF regens and therefore in short time the particle warning light/message will come on, then the DPF will start to clog and that will trigger limp mode.
Can anyone provide more details on code B1805:62? I'm struggling to find further information on it. The van has no issues starting.
TIA
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Citroen Spacetourer code B1805:62 Starter Fault - Consistency
MonsieurM
- x 6945
Re: Citroen Spacetourer code B1805:62 Starter Fault - Consistency
Unfortunately this is non-specifically characterised fault, so could be multiple systems causing it, but here is the descriptor code for you:
| Fault Code: | B1805 62 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: | - |
| Symptoms: |
| Suspect Areas: |
