p1339 combustion misfiring
ORENSONEGO1978
Unread post by ORENSONEGO1978 »
Hello everyone
my car citroen ds4 2013 so chic
Check engine light came on
And the engine went into limp mode
And the fan works hard,I connected obd2
Fault code, p1339 combustion misfiring (impact on catalytic converter)
Does anyone know what the problem is ?
thank you all !
PaulC5
x 696
Re: p1339 combustion misfiring
Unread post by PaulC5 »
If it is a petrol engine it could be an ignition coil fault on cylinder 3 or possibly a spark plug. Note 3 is from the gear box end. However, if you post your vin admin will be able to look up this fault code against your car.
https://www.ds4ownersclub.co.uk/threads ... 0sensor%20.
ORENSONEGO1978
PaulC5 wrote: 25 Aug 2024, 11:29 If it is a petrol engine it could be an ignition coil fault on cylinder 3 or possibly a spark plug. Note 3 is from the gear box end. However, if you post your vin admin will be able to look up this fault code against your car.
Thank you very much for your reply
yes it is petrol
4 plugs were replaced two months ago
The ignition coils look pretty old except for one
Don't know when the previous owner replaced them,Sometimes it gives me these fault code as well,P0303
Cylinder 3 Misfire Detected
P0313
P0313
Misfire Detected With Low Fue
ORENSONEGO1978
I would be happy if admin
Will check for me by engine number :)
x 6945
You have a 1.6 THP 16V 163 (EP6CDT M).
As for the second P0313 fault, not a good idea to run with low fuel levels when trying to troubleshoot fuel problems, as this just adds to the issues.
Fault Code: P1339
Description of Fault:
  • Combustion misfiring (impact on catalytic converter): No. 3 cylinder.
  • Description of the diagnostics: Cylinder 3 misfirings (Possibility of damage to the catalytic converter).
  • Conditions of activation of the diagnostics: The following conditions have to be met:
    - Engine management ECU in main triggering phase
    - Engine speed above 500 rpm and below a threshold defined in the engine ECU
    - Torque less than a threshold defined in the engine ECU
    - The crankshaft and the camshaft are synchronised
Conditions for Fault to clear:
  • Stop the engine and restart, in order to re-inject into the cylinders cut off following the detection of ignition misfirings
Downgrade Modes whilst Fault is active:
  • Deactivation of the richness regulation
  • Deactivation of the canister purge function
  • Cutting of cylinders if fault persistent
  • Deactivation of checking of the canister purge
  • Switching on of the warning lamp and/or warning message: Warning lamp MIL
Symptoms:
  • Starting impossible
  • Starting difficult
  • Unstable idling
  • Idle speed too high
  • Lack of power
  • Engine hesitation
  • Emissions outside the norms
  • Excessive fuel consumption
Suspect Areas:
  • Electrical harness
  • Sparking plugs
  • Ignition coil
  • Fuel injector
  • Engine ECU
  • Engine compressions
Fault Code: P0313
  • Low fuel level signal: Minimum level reached.
  • Description of the diagnostics: Suspicion of lack of fuel in the tank.
    - Engine management ECU in main triggering phase (After 1 seconds)
    - The "fuel level" information received from the CAN is valid
    - Fuel level low
  • 10 s after refilling the tank
Downgrade Modes whilst Fault is active: -
Symptoms:
  • Information fault
Suspect Areas:
  • Fuel level indicator
