Hoping you can help me
I have a 2011 Citroen C3 Picasso. airdream+
Firstly experienced loss of power, and was diagnosed with sized turbo
Turbo then replaced and came up with DPF clogging
DPF cleaned and then came up with engine repair needed warning light
Still have loss of power and no one seems to be able to find out what’s wrong
Any help much appreciated before I bankrupt myself with more repairs!!
Loss of Power
- x 6945
Re: Loss of Power
When the DPF was cleaned, did they inform the engine ECU that the DPF had been replaced? This has to be done otherwise it won't know that it has been cleaned / replaced.
Once you've confirmed this, I suggest you put the actual fault codes up here with your VIN so we have something to go on.....
Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
