I had a leaking injector but was runing fine i replaced the seal and guide now it will not run....
i have fault code
P2150 fuel injector group B supply voltage circut low.
P0201 injector circuit/open cylinder 1
P0202 injector circuit/open cylinder 2
I have unplugged the fly lead that feeds these two injectors from the injectors and from the loom and they test ok.
when doing a meter test on the 4 injectors they all 07 ohms across the pins and no short to ground....when checking meter readings on other cars they are about 170 ohms so not sure why these all test .07 or 0.7 i carnt remeber now its been a long week.
What eles do i need to test? Thanks..
