Central locking issue
Nigwino15
I have 2011 dispatch 1.9 diesel, while driving it displays my rh door is open when it is not also my central locking has started to play up sometimes locks and sometimes not more recently not .I have change battery in fob which has made no difference .Any advice would be appreciated thanks
moizeau
- x 423
Re: Central locking issue
I had the same issue. RH front door, not the sliding door. It's the switch inside the lock. If you lean on the door it may show as closed. I tried resetting the the lock and hasp to no avail. Ended up cutting the wire from the lock (behind the door card). Only downside is the interior light doesn't come on when you open the door.......but I can lock the van.
Pete
Nigwino15
Thanks will try that
moizeau
- x 423
Only the single wire that tells the car the door is open not all of them.
Before you cut anything you can check the lock mech by flicking it closed with a screwdriver (door open)
Pete
