Door sensor ds4
Timo10
Door sensor ds4
Hi . My door sensor keeps going off on the drivers side and middle light comes on everytime I go over bump or turn right !!! Does anyone no where the sensor is located or how to turn it off ?? Thanks for any help..my car is cittion ds4 2012
PaulC5
- x 696
Re: Door sensor ds4
It might be built in to the lock. You could check for any wiring damage, with the driver's door open, close the door lock around a screwdriver and then move the wiring between the door and pillar and see if the light comes on. To check wiring nearer the lock will need the door card removing.
