C4 grand picasso energy economy mode
Northman1968
Unread post by Northman1968 »
Just bought a Citroen C4 grand picasso and I have noticed that when you turn the engine off, I then try and listen to the radio or even activate the windows, it then goes into ," ENERGY ECONOMY MODE ACTIVATED," and then shuts down,this is extremely annoying,is there anyway I can turn this off as I have looked but it doesn't seem to give any options,any help much appreciated thanks
x 1490
Re: C4 grand picasso energy economy mode
Welcome along.
Unfortunately you can't disable this, it's a failsafe to protect the battery. However if it comes on soon after shut down, even after a decent run, it probably indicates the battery is past its best.
Arkis
x 27
Unread post by Arkis »
It is a safety measurement for draining the battery. You can turn it off only via Lexia diagnostic tool. I don't recommend it.
For me, the economy mode usually pops up after about 15-20 minutes of using the battery only. If it starts sooner, it might be because of a weak battery. If so, check battery health and charging capacity of the alternator.
Citroen C4 Picasso 2013, 1.6 e-HDI 85kW, 6 speed manual
Peugeot 206, 2005, 1.4i 8v, 55kW, 4 speed AT
Peugeot 208, 2019, 1.2i PureTech, 61kW, 5 speed manual
Opel Insignia, 2015, 2.0 CDTi, 120 kW, 6 speed AT
Hyundai Santa FE 4WD, 2015, 2.2 CRDi 145 kW, 6 speed AT
