C4 grand piscasso multiple issues
Kayla
Unread post by Kayla »
Evening all,
I have a c4 grand picasso, it failed mot and mostly where and tear things however one or two things we can't seem to figure out the issue.
This is our 2nd gp.
1) automatic hand brake fault- the light flash on and the brakes either engage and don't realise or the won't go one, we have changed the button and checked fuses but it still its coming on?
2) registration lamp not working-we have changed the bulbs check the connections, we can't seem to find the fuse to check those.
Any help would be appreciated.
Many thanks
Michala
Reason: Moved to Citroen Forum
x 6945
Re: C4 grand piscasso multiple issues
Hi
I'd advise against swapping out components until you have had it properly diagnosed as to what the fault is. Electronic Handbrake faults are often associated with the ESP / ABS system which controls the electronic handbrake. So I suggest you get id properly diagnosed if you can, preferably by somebody with 'Diagbox' and pop any fault codes up here with your VIN.
Kayla
Ok thank you so much will its going in to a garage tomorrow for suspension replacement so will ask them if they are able to plug it in thank you so much.
Will update when done.
x 1490
What year is it?
