I have a citroen relay xlwb on 85k. After reading about the Eolys fluid i thought i would check. Took the tank off and it feels empty. Iv had no dash warning etc. But assume I should re fill it. Garage quoted 360. I'm thinking of doing it my self. I know I need to reset the counter and likely purge the system. Will a topdon 800bt reset it and can any one confirm would fluid i need. It's a 2.0 blue hdi 2018
Cheers in advance
Relay xlwb Eolys fluid
Jcbassett85
Reason: Moved to Citroen Forum
- x 6945
Re: Relay xlwb Eolys fluid
Will need the VIN to check. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Jcbassett85
Hi the vin is VF7**************[VIN obfuscated, can be read by forum staff] I believe it's the powerflex I want and it has the blue connector. Thanks
- x 6945
Yes, Powerflex for this build date.
