Citroen c5 2.0i 16v spark plugs
thundermaster
x 5
Unread post by thundermaster »
A question
When you replace spark plugs, do you have to do any adjustment to them? Also, is there any chance of the ignition coil to be erratic and I have vibration on engine?
seanrx
x 6
Re: Citroen c5 2.0i 16v spark plugs
Unread post by seanrx »
Adjustment?
No, not on my old 2.0i. I had three different types no problem. Multi point plugs too, easier starts.
And screw them in tight! I once fitted mine at night, car drove as if a failed coil pack.
If vibration on engine, check the coil bolt holes for cracks. This old plastic can fail.
