Hi all
I've had a search and read through the forum and couldn't find anything covering this specific set of codes so decided to post.
The vehicle is a 2011 Citroen C3,1.4 diesel. It has the engine management light on, and I've read the codes (scanmaster elm) as follows:
Stored codes:
P0003
P0245
P1352
P1641
Pending codes:
P0003
P0245
No 'permanent' codes
Symptoms are occasionally takes a few turns to get it started, but fine when warmed up. Sounds fine when running.
We have tried the earthing strap trick mentioned on this forum (MM01 to fix P1352) but the error codes remain the same.
Car belongs to a friend, worth noting it has done many very short journeys (0.5miles) daily and longer runs on weekends (50miles+)
Would really appreciate any advice on what to look at next.
Thanks for all the information shared on the forum!
Citroen C3 error codes P0003, P0245, P1352, P1641
HenryHoover
- x 6955
Re: Citroen C3 error codes P0003, P0245, P1352, P1641
You'll need to provide the VIN, so the codes can be related to the specific engine ECU. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
HenryHoover
Thanks for your response, I'll get hold of the number and post an update.
HenryHoover
Hi
Managed to get hold of the VIN:
Thanks.
Thanks.
