Guys I'm working on a water damaged 2021 Partner 1.5 diesel.
I've been given some wiring diagrams which have been a great help.
1) Engine starting
2) Electronic fuel injection
3) ECU connector pins
I would really like some info on the BSI pins and the ABS module and steering sensor.
I have paid for an hour on Service Box but cant seen to navigate to any wiring diagrams.
Vin. VR3**************[VIN obfuscated, can be read by forum staff] EFYHYC MJ573681
Any advise would be great.
1.5 Partner K9 wiring diagrams
Wattie
Re: 1.5 Partner K9 wiring diagrams
Good evening,
can anyone explain or guide me how to see the wiring diagrams for this van.
On service box or by any other means please.
- x 6955
You'll need to pay for a subscription with Service Box for technical documentation. Access is timed from first use, so be aware.
Wattie
Yes, that bit I understand.
I paid for an hour but couldn't find any wiring diagrams.
I can’t seem to navigate the site to find them!
- x 1056
Did you Just pay for a parts subscription or was it for technical documentation? You need the technical documentation subscription to view wiring diagrams.
Once you have entered VIN on the main screen you should have several tabs Parts, Repair info etc. There is a tab that just says diagrams, this will open up SEDRE to view the diagrams.
See my post here that has a screen shot of the tab location > viewtopic.php?p=720422&hilit=servicebox ... ms#p720422
Wattie
Some good progress with the Partner, despite not being able to use Service Box diagrams!
I have it running but only on a couple cylinders.
Fault code P2687 is the trouble.
Can any one confirm please?
P- power train
2- fuel injector circuit
6- fuel temp circuit
8- eng speed malfunction
7- timing solenoid malfunction
The engine sounds like it’s off the timing.
P- power train
- x 1056
Did water get taken into the engine intake?
Have you checked the valve timing?
- x 1484
P2687 only seems to be fuel heater, wouldn't stop it running on 4. Have you got live data? What are the injection timings saying?
Wattie
I’ve reconditioned the engine top half, and double checked the timing.
I don’t have live data.
The injector timing is definitely off. When I pull the connector on cyl 2 or 3 it runs the same.
