Hi, I have a Citroen C4 Grand Picasso I Phase II (2013) and want to perform a BSI Reset. The instructions say to disconnect the negative battery terminal, but it's inaccessible. Only the positive terminal is reachable for me.
Will disconnecting the positive terminal instead of the negative still successfully perform a BSI Reset?
BSI Reset using positive battery terminal ?
- x 1942
Re: BSI Reset using positive battery terminal ?
Yes it will. Just be sure to put a rag over the terminal when disconnected so as to avoid an accidental connection.
ismet
Thanks for the reply, Paul.
