Kangoo headlight and wiper stalk part numbers. Main beam not staying on and wipers not working on setting 1
Yewboy69
x 3
Unread post by Yewboy69 »
The main beam on the headlights do not stay on after the stalk is pulled back and clicked to stay on, but come on when the stalk is held back.
The wipers do not work in stalk position 1 but work as you would expect if you hold the wiper stalk between off and setting 1. As soon as the stalk 'clicks' into setting 1 the wipers freeze.
Both of these I am assuming are down to worn switches as its an older van but if anyone has any wisdom then it would be much appreciated!
Could anybody give me the part numbers for the indicator and wiper stalks on a 2005 Kangoo 1.5dci WF05 ZXG
Thanks in advance and sorry if theres a requests thread that I have missed!
x 6946
Re: Kangoo headlight and wiper stalk part numbers. Main beam not staying on and wipers not working on setting 1
I can't help you with Renault parts, sorry, as we only provide a PSA part service.
