Coolant refill - Air Lock
jscadden
x 4
Unread post by jscadden »
Just replaced the radiator after a leak and refilled it with approximately 5 litres of coolant. I have managed to get heat out from the heater but the radiator is still cold and the temperature gauge goes Max.
Is there a bleed screw somewhere or some method of clearing the airlock?
TIA
John
John
Xsara Picasso VTX 16V
VIN VF7**************[VIN obfuscated, can be read by forum staff]
x 6946
Re: Coolant refill - Air Lock
Exact same procedure as for this engine that I've written up (but you'll need to renew your membership for access to this section John):
C5 X7 DW10BTED4 Draining / Refilling Coolant
jscadden
x 4
Done that with pleasure!
John
x 6946
Thanks you for your membership upgrade renewal John. Just focus on the de-gassing part for non Euro 6 vehicles in the guide.
