P0560 ECU ESP electrical supply (intermittent)
508c5
x 4
Unread post by 508c5 »
Hello,
Can you share the protocol for this fault ?
Vin VF3**************[VIN obfuscated, can be read by forum staff] Peugeot 3008, 1.6l, petrol, 165bhp
Thx
x 6956
Re: P0560 ECU ESP electrical supply (intermittent)
Your VIN's incorrect - should be 5GZ, but I have it now anyway.
There is also the last 2 digits of the fault code missing, but generically with 00 as the last 2, it means the main battery voltage is too low.
Suspects:
Power relay
Ancillaries battery
Battery charge status unit
Engine management ECU
Electrical harnesses
Connectors
508c5
x 4
You are correct per 5gz
thank you
