207CC roof partially opening
Tori
Unread post by Tori »
HI,
I got myself a 207CC from 2007 and initially everything worked fine. However, recently the roof does not open complete any more: the windows go all down, the boot opens fully, the roof starts opening but stops after about 10 cm. I'm pretty sure one of the microswitches is the problem here, anyone know which one this specific is? I'm suspecting the one left front at the windscreen but not sure, so any help appreciated. In the mean time i'm also gonna try to get a readout of the car, hopefully this will help as well.
Tori
Re: 207CC roof partially opening
Nobody? :-(
x 1469
Unread post by xantia_v6 »
There have been very few problems reported here involving the folding roofs, and I don't think I have seen any with the symptoms you described.
Getting diagnostics done, including switch readings and actuator tests would be a good investment.
If I had to guess at a cause, I would say that you have a broken wire at one of the roof hinge points
Nell
New User
Unread post by Nell »
I solved problems with my roof partially opening or not fully closing by replacing the car battery.
I discovered that was the problem when a friend suggested I try closing the roof with jump leads attached.
I've had zero issues with the roof mechanism since i had the new battery installed.
Tip: Don't buy a cheap or 2nd hand battery.
