RT6 - hidden functions
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
Cristache39
x 3
Unread post by Cristache39 »
Cheers,
Today during the activation of “Shows pop up info as on instrument cluster” and “enable HARM03” functions through DatExplorer i found out another ones that are having the value “0” which means that are disabled, so no info shared on navigation.
As an example:
Display water and oil temp and TPM screen
“List of warnings” in SET-UP menu
“Status of functions” in SET-UP menu
AIRC menu present
Automatic parking brake submenu in SET-UP and others…
Is here somebody that worked with DatExplorer and enabled this functions?
A few of them i think that can be helpful and others only like a cool feature.
Have a good day!
Cristache39
x 3
Re: RT6 - hidden functions
Up!
x 6955
You really need to be careful what you change here or it may have an adverse effect.
Certain information is set specifically the way it is, depending on the other equipment and options fitted - and for the different vehicles which have specific difference say between Peugeot, DS and Citroen display and the way the info is routed and displayed.
