Citroen AX TU3 Engine Rebuild? Questions!
cheesesliceking
hello,
ANyone know how much an engine re-build costs? & how long it takes? and any good places in W Yorks?
I've spoken to LAD & they'll do the whole thing for 1500 which includes uprated Cams, port polish etc etc etc & that bumps up the power to 115 from 85 as standard.
Cant decide to go for that or just get a basic re-build & start tweeking myself from there.
Any opinions?[:p]
Any opinions?[:p]
AndersDK
csk -
tell me - are you honestly & seriously prepared to invest UK£ *1500* in rebuilding your engine ? - for your 10y's old (or more) AX ?
And that's just the engine rebuild - then you first have to remove the engine - and refit it when job done. Unless you find another donor engine.
Look around for a low miler post '88 BX14 which have the same type TU 75Bhp engine in dead standard setup. Add a double carb setup - and you are close to 100Bhp peak.
Would cost you little more than a 100.
bxbodger
I agree with Anders on this one; this is a huge amount of money to spend on an engine rebuild!
Its about 3 to 4 times the cars worth; if you want to go quickly use the money to get yourself a good Golf or 205 GTI!
Even a basic rebuild with rebore, new rings, pistons, oil-pump, shells, crank-grind, and the millions of other odds and sods; oil seals, gaskets, circlips, head-skim, valves, springs and so on, is going to cost I would reckon about 500 notes and thats if you do all the dismantling and rebuilding yourself!!!
uhn113x
- x 3
Hi CSK
Aaaarrrggghhh - you might as well light a bonfire with fivers. If I could not do the work myself, I would just get an engine from a scrappy. I would probably do the same, if I could find a car written off because of accident damage. Or do what Anders suggests - BXs are virtually given away here!
Plenty of good yards here in West Yorks!
Note to BXBodger - it is not what the car is worth that is to be taken into account, it is the replacement cost [:)] It would make sense to spend £200 on a £100 valued car, if replacing it would cost £500; that is the purchase cost plus sorting out faults. And <b>all</b> secondhand cars have these!
cheesesliceking
you tellin me i could get a decent 205 gti or a Golf Gti for 1500 that I wouldne ned to do ANY work to??
The only thing wrong with the AX is the engine, the body is rust free & Dont want any other car.
The 1500 was all in ,including removal re-wiring, VAT etc. I'd stand no chance of finding the BX Engine Anders, besides if its just as old its going to me just as worn out id have thought
suppose i coudl always just switch it for a VTR lump
cheesesliceking
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by uhn113x</i>
Hi uhn113x
Thats why i wanted to keep the car & change the engine! you just seemed to explain it better than i did! cheers![:)]
I dont see the advantage of sourcing a seperate engine? wouldnt it just mean more £'s for the purchase of it? & then i'd have no idea of the condition. then there's removal & transport. hmm not seeing the advantage to be honest.
BTW, where in West Yorks is you? have you seen the huuuuuuuuuge Yard near the White Rose in Leeds?? biggest ever but a total mess the guys have no clue ...[B)]
Hi uhn113x
jeremy
I don't see anything dificult in overhauling this engine yourself. As yours has done a considerable mileage there may be advantages in doing another lower mileage one but thats up to you. As far as I can see the engine is another classic Peugeot/ Citroen wet liner engine and therefore won't need boring, just liner/piston replacement. if the bores and pistons are not worn and you just want to freshen it up then a new set of rings may help.
The crank should be measured but if its within limits and unscored then a new set of bearings will bring that back to new spec. grinding and oversize shells will not be very expensive. Obviously the block should be thoroughly examined and cleaned, re-gasketed and the oil pump and its druve replaced if necessary.
You're thinking of head work which is of course rather specialised and may take some time. a spare head will come in useful here. Simply to re-use yours without tuning the valves are going to need attention and should be re-faced/seats cut to ensure a good seal. The rest of the valve mechanism needs a good examination and any worn bits replacing.
This is the work that will be done if you have the engine overhauled or get a recon one - so whats the problem - you don't even have to get these re-bored!
If I was able to find a good low mileage cheap one I would simply as there may well be savings in some of the components (crank grinding etc) and also I could work on it at my leisure rather than having the car off the road. I also have the satisfaction of knowing thaI've done the work and know that the job has been done thoroughly!.
jeremy
jeremy
bxbodger
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Note to BXBodger - it is not what the car is worth that is to be taken into account, it is the replacement cost It would make sense to spend £200 on a £100 valued car, if replacing it would cost £500; that is the purchase cost plus sorting out faults. And all secondhand cars have these!<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
I think people are missing the point here- yes it is worth spending 200 odd on a valued car, but no mastter how much I love it I would not pour 1500 quid into my 15 yr old 210000 mile BX!!!!
I could get a very good late Xantia for that or an absolutely top XM. I could also get a Mondeo or a pre-facelift Passat, both good cars!!!
1500 buys you a hell of a lot of late car these days, particularly if you go to the auctions and know what you are looking for- it just is not worth putting into a 10 year old car!!!!
cheesesliceking
jeeez! i think I should have made the post a bit more specific..
What I actually asked for was opinions on the engine re-build & what that enatils (pretty much what Jeremy, Anders & uhn113x answered[:D]) & if the price that LAD had quoted was any good taking into consideration the increased power (from 85 to 115). (still unsure of this)
What <u><b>I DIDNT</b></u> ask for were peoples opinions on how i should spend my money & how it wasn't worth it. I agree with you, i think you have missed the point, not once did you offer anything constructive, just your opinions... thanks[xx(]
CITMAN
Would a later 1.4 tu engine out of a scrap saxo or xsara do the job. You can pick up a 95 zx 1.4i engine for £150 with 60k on it from a citroen specialist scrap yard, as ive enquired about it before when i thought my motor was knackered. All u will need to do is swap the injection gear for the carb and bobs your uncle.
cheesesliceking
np
[quote]Originally posted by cheesesliceking
I`m sorry,i`m sure it said at the top "any opinions"???
CITMAN
It did say any opinions? I missed that comment by "cheesesliceking" Must admit that the comment was a little ****ty to say the least. A little respect goes on a long way. So what if the suggestions werent what you where expecting. Personally I thought that they were relevant to your orginal post.
"Personally I wouldnt even dream of spending £1500 on a old car which isnt even worth that to begin with. It just doesnt make economic sense to do so"? That my "opinion any way".
cheesesliceking
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by np</i>
I`m sorry,
Apology accepted....
I`m sorry,
