Hi I have a 2014 peugot expert 2.0 rhh, I've replaced the engine and had the turbo reconditioned as a precautionary. Since I've put it all together I've no boost and this fault code. Would anyone have a diagram of the turbo/ egr vacum and power connectors? I've checked for vacum leaks etc to no avail,and I'm now thinking is there an issue with the refurbishment turbo?
Thankyou for any advice.
Fault code p1497
- x 6956
Re: Fault code p1497
Not with out a VIN. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Thomasjames[1955]
Thankyou!
- x 6956
With the exception of the wiring codes, most of the component codes are indexed here:
PSA Electrical Diagrams - Wiring & Symbols Codes Index
A few to start you off...
1297 : Electric EGR valve
1229 : variable geometry turbo regulator electrovalve
1374 : turbo position copy sensor
13A1 : RAS mixer repeat sensor
13A3 : inlet air temperature and pressure sensor
1253 : all or nothing solenoid valve (EGR)
1361 : turbocharged air heater electrovalve 1
Thomasjames[1955]
Thankyou!
VF3**************[VIN obfuscated, can be read by forum staff].
Thankyou for this information, iam just new to the forum,,really appreciate the help!!
