Citroen Jumper III 2016 (Euro6) - Instrument panel and Airbag ECUs communication errors
perfidus
- x 6
Hello,
I'm starting this topic because I need help with some issues and error codes. My Citroen van is a BB furgon from 2016, chassis VIN number is VF7**************[VIN obfuscated, can be read by forum staff].
Especially need to sort out some weirdo things that showed up after scanning my "new" Jumper van with Diagbox 7.83 (and the same with 9.68 Free).
I'm using a Lexia interface full chip FW 921815C , recently purchased from this shop: https://www.aliexpress.com/item/1005007009192418.html?
So, I have Instrument panel ECU communication trouble and Airbag ECU communication trouble. What can cause that?
As I mentioned in my first post, the van was converted into a camper and I suspect that some wiring may be affected.
First thing noticed - passenger seat belt tensioner and switch is disconnected from the yellow harness underneath but there are no warning lights on the instrument panel.
The second - although the engine has a few errors and check engine message on the display, the Check engine warning light is off.
I can say that it was forced OFF by someone to pass the inspections, the light doesn't come ON at ignition ON.
I need to check also the airbag light, as I said there is no indication of a fault with Airbags.
The instrument cluster is working fine, no signs of tampering on the other lights, but I will return with a picture of the panel at ignition ON maybe someone will observe anything odd.
Any suggestions for a starting point?
Those who don't know history are destined to repeat it!
- x 1056
Re: Citroen Jumper III 2016 (Euro6) - Instrument panel and Airbag ECUs communication errors
Are you using the Fiat adapter with diagbox?
If not you won’t get comms with all ECUs
perfidus
- x 6
No i don't. Thank you for your suggestion/confirmation, I was afraid that this is the case, the software asked for the switch on the adapter to be "in position B".
- x 1056
- x 1056
What is the issue with the airbags then?
Its not uncommon if the van is being converted to a camper that the middle seat is removed. If a resistor is not used in place of the old seat belt pre tensioner it will cause an airbag fault .
perfidus
- x 6
Thanks. The factory passenger seats are moved in the back behind a table and the front seats are rotating type, the one of the front passenger being exactly the same as driver seat. Noticed the yellow connector underneath - îs not being wired to the floor harness.
EDIT: I see the point of your question, airbag may be OK (the van has only one driver airbag) - the problem is with one seatbelt pretensioner, the front passenger's one is not connected. When I'll succeed to connect with Airbag ECU I will see what is missing/in error.
perfidus
- x 6
Waiting for the PSA S.1279 Interface to arrive, i bumped into this topic:
viewtopic.php?p=772678#p772678
I think I asked before - is there any source of information to find the original equipment of the van with the VIN number?
Without the adapter it appears to be two more modules that can't communicate. But i doubt that those modules are corect (such as Blind Spot Monitoring left and right)
My campervan also has a dumb aftermarket 1 DIN unit (but I don't know what equipment was fitted at the factory, if any) - could it be possible to affect the dashboard warning lights?So for example, if your vehicle provides key messages via the head unit and you have an aftermarket system, then it won't be able to communicate issues to the driver. So you are on dodgy ground to start with
- x 6946
If you're asking what radio equipment you had from factory, then the answer is none! It only came with 4 speakers, but no radio.
Here's you build sheet from factory:
| Vehicle Characteristics | |
| Vehicle family | RELAY III |
| AS/RP N° | 14483 |
| Warranty Start Date | 02/09/2016 |
| Engine serial number | 10 DYZZ 4012521 |
| OPB | J0ZI |
| BER | e3*2007/46*0046*11 |
| General Information | |
| PRODUCT TYPE | COMMERCIAL VEHICLE |
| COMMERCIAL MARQUE/COMPONENT TYPE | CITROEN |
| VEHICLE FAMILY | RELAY III |
| SILHOUETTE | EXTENDED VAN H3 TYPE 16H |
| TRIM LEVEL | STANDARD |
| ENGINE | DW10FUC FAP DIESEL |
| TRANSMISSION | BVM6 |
| PAINT TYPE | NON-METALLIC PAINT |
| BODY COLOUR | EWP - BANQUISE WHITE PAINT |
| INTERIOR TRIM TYPE | CLOTH DARKO + TWILL "35" |
| UPHOLSTERY COLOUR | "FX" |
| GEARBOX (CHARACTERISTICS) | BVM6 MLGUC14 |
| CONVERSION GUIDANCE | WITHOUT CONVERSION |
| DEFINITION TO FOLLOW | MID-LIFE |
| ENGINE (TYPE) | EW/DW |
| STEERING | VARIABLE POWER STEERING |
| SPEEDOMETER DRIVE | TACHO TORQUE 18X14 |
| Fuel Supply-Engine | |
| FUEL | DIESEL GRADE DA/DE/DE+ |
| CAPACITY | 2000 CM3 |
| VEHICLE EMISSIONS STANDARD (TYPE APPROVAL) | DEPOLLUTION EURO6 (HOMOLOGATION) |
| CRANKCASE GAS CIRCUIT HEATING | WITH HEATER CASING GAS CIRCUIT |
| PARTICLE FILTER | WITH PARTICLE EMISSION FILTER |
| STOP AND START | WITHOUT STOP AND START |
| Gearbox Transmission | |
| FINAL DRIVE RATIO | CP 14 X 75 |
| WHEEL (TYPE) | STEEL WHEELS |
| INFLATION PRESSURE LOSS INDICATOR | WITHOUT TYRE DEFLATION INDICATOR |
| GEARBOX TYPE | MLGU6 MANUAL GEARBOX |
| Suspension-Steering-Brakes | |
| TRACTION CONTROL | ANTISLIPPING |
| SUSPENSION | DOUBLE-LEAF RR HEAVY DUTY SUSPENSION |
| SUSPENSION (ARCHITECTURE TYPE) | METAL SUSPENSION |
| DYNAMIC STABILITY CONTROL SYSTEM | ELECTRONIC STABILITY PROGRAM |
| EMERGENCY BRAKING ASSISTANCE | WITH EMERGENCY BRAKING ASSISTANCE |
| Body Fittings | |
| TOWBAR | WITHOUT TOWBAR |
| AERIAL | LONG ROOF AERIAL |
| SKIP | W/O FLAT HAMPER |
| CABIN | CLOSED SINGLE CAB |
| CHASSIS | STANDARD CHASSIS |
| PAYLOAD | HEAVY PAYLOAD 16Q |
| SIDE MOULDINGS (TYPE) | LATERAL PROTECTOR MASS TINTED |
| EXHAUST TAILPIPE | LEFT-HAND SIDE |
| INDICATORS | LONG VEHICLE SIGNALLING LIGHT |
| ADDITIONAL SHIELD (UNDER ENGINE) | W/O ENGINE UNDERSHELDING |
| EXT. REARVIEW MIRROR COMP. FUNCTION | EXT MIRROR MANUAL-FOLD BACK |
| OPENING OF MOVING PANEL | DOOR OPENING AT 270 DEGREES |
| WINDSCREEN WIPER | FRONT WIPER BLADE W/O RAIN SENSOR |
| HEADLAMP WIPER | W/O HEADLAMP WIPER |
| SIDE LOAD DOOR | RH SLIDING SIDE METAL DOOR |
| BUMPER | DYED FRONT/REAR BUMPER |
| MUDFLAP | WITHOUT MUDGUARD |
| ROOF | STANDARD ROOF PNL |
| LUGGAGE RACK | WITHOUT ROOF BARS |
| FRONT FOGLAMP | NO FRONT FOG LIGHTS |
| EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) | PASSENGER ELECTRIC DOOR MIRROR |
| SPARE WHEEL MOUNTING | STANDARD SPARE-WHEEL CARRIER |
| WHEEL EMBELLISHER (TYPE) | WHEEL TRIM WITHOUT CUSTOMER CHOICE |
| BODY CONVERSION | WITHOUT |
| REAR WINDOW (TYPE) | WITHOUT REAR WINDOW |
| GLASS (APPEARANCE) | TINTED |
| WINDOW (TYPE) | LAM W/SCREEN + SIDE + RR TOUGHENED |
| SIDE WINDOW (COMM. VEH. ONLY) | WITHOUT SIDE WINDOW |
| ROW 3 SIDE WINDOW | WITHOUT SIDE WINDOW 3ND ROW |
| HANDS FREE ACCESS AND STARTING | NO ACCES AND HANDSFREE STARTING |
| Interior Fittings | |
| ANTI-THEFT ALARM | WITHOUT THEFT PROTECTION ALARM |
| REAR SEAT | WITHOUT REAR SEAT POSITION |
| SUPPLEMENTARY SEAT | WITHOUT SUPPLEMENTARY SEAT POSITN |
| CABIN SEAT | 2 PLACES PASSENGER BENCH |
| CIRCUIT BREAKER | WITHOUT BATTERY CUT-OFF |
| CLIMATE (AMBIENT TEMP) | COLD COUNTRIES |
| SPEED GRADUATIONS | SPEED GRADUATION IN KM/H |
| DRIVING POSITION | LEFT-HAND DRIVE |
| REMOTE CONTROL | REMOTE CONTROL ASSEMBLY |
| ADDITIONAL HEATING | WITHOUT ADDITIONNAL HEATING |
| FRONT HEAD RESTRAINT (STYLE) | OPEN FRONT HEAD RESTRAINT |
| TIMER | WITHOUT TACHOGRAPH |
| RADIO CONTROLS | WITHOUT REMOTE RADIO CONTROL |
| SIDE DOOR CONTROL MECHANISM | NON-MOTORIZED, ELECTRIC LOCKING SIDE DOOR |
| FRONT PASSENGER SEAT HEIGHT CONTROL | WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT |
| DRIVER SEAT CONTROL | DRIVER SEAT MANUAL CONTROL |
| FRONT PASSENGER SEAT CONTROL | PASSENGER FRT SEAT MANUAL CNTR |
| FRONT SEAT | WITH DRIVER’S SEAT |
| DRIVER SEAT ADJUSTMENT | DRIVER’S LUMBAR ADJUSTMENT |
| FRONT PASSENGER SEAT ADJUSTMENT | WITHOUT FRONT PASSENGER’S SEAT ADJUSTMENT |
| FRONT SEAT ARMREST | FITTING WITH DRIVER’S FRONT ARMREST |
| STOWAGE BIN | WITHOUT SETTING BOX |
| SATELLITE NAVIGATION SYSTEM | WITHOUT NAVIGATION SYSTEM |
| TRAFFIC INFORMATION READER | WITHOUT LATERAL TRAJECTORY MONITORING |
| MISC. INT. ACCESSORY | DOCUMENT HOLDER TABLE |
| HEATING ELEMENT | NON HEATED SEAT |
| FRONT LATERAL AIRBAG | WITHOUT FRONT SIDE AIRBAG |
| PASSENGER AIRBAG | NO PASSENGER AIRBAG |
| ADDITIONAL AIR CONDITIONING | WITHOUT ADDITIONAL AIR CONDITIONING |
| EXTERIOR REAR VIEW MIRROR (HEATED) | HEATED DOOR MIRROR |
| REAR MOVING PANEL | 2 REAR HINGED METAL DOORS |
| COURTESY LAMP | FR+RE DOORS CONT - FR+RE INTERIOR LAMP |
| FRONT SEAT GUARD | REMOVABLE CAB PROTECTION PANEL |
| RADIO RECEIVER | 4 SPEAKERS WITHOUT RADIO RECEIVER |
| REFRIGERATION | SINGLE AIR CONDITIONING |
| CRUISE CONTROL | REGULATOR AND SPEED LIMIT |
| DRIVER’S SEAT HEIGHT CONTROL | FR + RR DRIVER HEIGHT ADJ |
| REAR VIEW MIRRORS | STANDARD REAR VISION |
| DRIVER AIRBAG | DRIVERS AIR BAG |
| INTERIOR PROTECTION | MID-HEIGHT INTERIOR WALLS PROTECTOR |
| OBSTACLE DETECTION SYSTEM | WITHOUT OBSTACLE DETECTOR |
| LOCKING CONTROL | NORMAL + AUTOMATIC LOCKING |
| STEERING WHEEL | STANDARD STEERING WHEEL |
| PASSENGER SEAT PACK | BENCHSEAT WITH 3-POINT CENTRAL BELT |
| SUPPLEMENTARY HEATER | WITHOUT ADDITIONAL HEATING |
| AUDIO PACK AUXILIARY SOCKET | WITHOUT AUDIO PACK AUXILIARY SOCKET |
| Electrical | |
| BATTERY (FITTING) | UPPER BATTERY |
| STARTER MOTOR | CLASS 6 STARTER MOTOR |
| SPECIAL LIGHTING | FRONT DAY RUNNING LIGHT (DRL) |
| Component Manufacturers | |
| Miscellaneous | |
| SPECIAL SPECIFICATION | STANDARD |
| RADIO HEADPHONE SOCKET | WITH ACCESSORIES SOCKET |
| PLATE | WITHOUT PLATFORM FLOOR |
| SET OF KEYS | 1 HIGH FREQUENCY REMOTE CONTROL KEY+1 MAIN KEY ONLY |
| COUNTRY ADAPTATION | WITHOUT |
| EMERGENCY EQUIPMENT | W/O HELP EQUIPMENT |
| SURFACE CONDITIONS | GOOD TERRAIN |
perfidus
- x 6
Great, thank you!
So, no Blind Spot Monitoring as expected:
TRAFFIC INFORMATION READER - WITHOUT LATERAL TRAJECTORY MONITORING
Another thing that i must check:
FRONT FOGLAMP - NO FRONT FOG LIGHTS
There are some Foglamps in the front bumper but I nerver found the ON/OFF button, it is not on the hazard switch panel.
They are aftermarket then.
- x 6946
So just to clarify: Lateral trajectory monitoring is actually Lane Departure Warning System, not Blind Spot Monitoring.
Active Blind Spot Monitoring usually includes additional sensors in addition to the front & rear parking sensors, The Blind Spot system has an additional 4 sensors, 2 on the front and 2 at the rear usually on the wheel arches facing outwards to detect passing objects.
As for fogs, these are referred to as 'complimentary Headlight kit' and if factory fitted (which weren't from factory in your case) will be located here:
perfidus
- x 6
Got the adapter for Jumper III, put it on the Lexia interface and the results are the same! See picture.
One interesting fact, the SW version in the ECU is from 2017, the car is from 2016. I think someone did something in the past.
- x 6946
Software version for what ECU?
It's not unusual for ECU software to be updated, like the BSI or the engine ECU to fix issues after the car was built. This can happen when it is dealer-serviced and you may not be aware.
Second, despite what the ad says on Aliexpress, I wouldn't trust them as far as I could throw them regarding being a full-chip kit. I've seen it here before where people have bought from those places and they ended up with a cut down version with missing hardware on the boards. It may be that or a connection / pin issue, but I'd be returning it and getting one from a trusted source.
perfidus
- x 6
By ECU version i mean the engine ECU, DCM62_F
Regarding Lexia interface i hope you're wrong, the store has a high rating and the price was also above average, got it open and seems for me like the full chip version.
- x 6946
Most of the parts seem ok - except for the 10k Resistor that seems missing highlighted in yellow where it is supposed to be. This can affect CAN communication.
Although (3) seems present, (1) & (2) don't:
perfidus
- x 6
Very good observations, much appreciated.
It is a chance the missing parts to be the cause. R1 R2 in last picture are from the USB part of the interface, though.
But the next step I see is to check the wiring to airbag ECU and dashboard instrument panel, it's strange that the rest of ECUs are responsive, I could check and clear errors, do some actuator tests, read live data etc.
It can be a protocol not correctly implemented in Lexia (firmware?) , i'm going to dig the forum for more info about versions.
I might need also some 'heavy tools' such as updated schematics (what I have is from Boxer III Euro 5) and an oscilloscope.
ANYWAY...
Luckily the engine runs verry well, it have a new EGR (the old one was leaking coolant and I found some intermittent errors in engine ECU memory) and the only error is the DPF (P242F 97), is broken by the last owner and needs to be changed.
But beside this there is an Airbag/seatbelt issue, and the associated lights (that somebody else turn off by brute force).
Regarding AdBlue system (that seems deleted) there are more to mention and perhaps I will open a new topic.
ANYWAY...
