Hi.
I hope some one can answer theese questions i have.
1. The berlingo k9 headunit has no built inn GPS antenna.
Is it possible to fit this on the headunit? so i dont have to plug inn my phone every time i want the navigation to work.
2. Every time i start the car after i have used the bluetooth, its starts default on the FM band. Is this possible to change, so it startso on default DAB or Bluetooth
Berlingo k9 headunit
- x 6945
Re: Berlingo k9 headunit
No
Reason being the headunit has no Sat Nav hardware (GPS tuner etc,) so is not there to start with. The GPS antenna is only part of the equipment and you probably won't have that either.
