Hi All
Sandi & Simon from North Wales here.
We have recently bought a Citroen Dispatch XL and in the process of converting to a mini camper.
On trying to get a link from the 12V socket at the rear for a camera, we seem to have blown a fuse (at least that it what we hope it is) - the rear 12V socket and the 12V socket at the front under the display screen no longer working, but the one in the cubby hole (which they call a glove box in the manual) works fine.
Replacing a fuse - should be a doddle, HOWEVER...
Issue 1 - trying to find the fuse box - eventually managed to, hidden behind the cables under the glove box - nightmare to access the fuses - but hopefully doable (Simon thinks it should be).
Issue 2 - which fuse(s)???? In the Manual - they show different different fuses depending on whether it is Version 1 (ECO) and Version 2 (FULL)
Does anyone have any idea how I can find out if I should be referring to Version 1 or 2?
TIA
Sandi
Dispatch Fuses - Am I Version 1 (ECO) or Version 2 (FULL)?
SiSam
Sandi & Simon.
Converting a Citroen Dispatch XL to a mini camper
- x 6945
Re: Dispatch Fuses - Am I Version 1 (ECO) or Version 2 (FULL)?
You'll need to provide your VIN. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff. ECO and FULL are referring to the electronic architecture of the vehicle.
- x 1939
Even knowing what type of system is fitted might not be enough. On our 308 (with the Eco wiring and fuseboxes) one of the fusebox drawings in the handbook was wrong and I had to go to a PDF of the following year's handbook (might have been previous year's - can't remember) and print out the relevant page.
SiSam
Sandi & Simon.
SiSam
Paul-R wrote: 28 Jun 2024, 15:30 Even knowing what type of system is fitted might not be enough. On our 308 (with the Eco wiring and fuseboxes) one of the fusebox drawings in the handbook was wrong and I had to go to a PDF of the following year's handbook (might have been previous year's - can't remember) and print out the relevant page.
I have looked through so many PDFs and YouTube vids - my head is spinning
Sandi & Simon.
- x 6945
Ok, so for reference you have ECO Electronic Architecture.
SiSam
That's great - Many thanks for the help.
Sandi & Simon.
joshclark
Hi, Any chance you could look up my electronics architecture too?
My VIN is VF7**************[VIN obfuscated, can be read by forum staff]
